| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Cut Crown Molding on an Outside Corner with a Miter Saw
by Expert Village
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an outside corner with a miter saw. It is pretty similar to cutting on the inside corner, so if you just change your miter... Read More »
How to Cut Crown Molding on an Inside Corner with a Miter Saw
by Expert Village
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an inside corner. Crown molding sits against the wall usually at a 38 degree or a 45 degree that depend on the type of... Read More »
How to Use a Miter Saw to Cut Crown Molding
by Expert Village
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on a wall that takes a 45 degree turn. What we want to do is take the two pieces of crown and we will need to cut them both... Read More »
Mark & Cut the Outside Corners for Base Molding Installation
by Expert Village
I am Tim for Expert Village and we’re continuing on cutting outside corners for shoe molding. So, basically what I was saying about marking the back, you measure on the back side of your piece because that is going to be your short end and that is... Read More »
How to Use Polystyrene Picture Frame Molding
by Expert Village
These are 2 samples of polystyrene. Polystyrene is a foam that they add a hardener to and they put it into a molding. It molds it and shoots it out. I have picked up a similar frame that wood purposely to give you some clues. By looking at it you really... Read More »
