12" Radial Arm - Cuts - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-18-2010, 01:56 PM   #1
12" Radial Arm - cuts
When cross cutting the piece on the left side of the blade is square but the piece on the right has a 88 deg cut(just not square!). The piece on the left has blade and burn marks, while the piece on the right side does not. Blade is 48 tooth carbide with lots of service but seems sharp. Is it just a new blade in my future. I'm cutting oak. TY.
mikevan1 is offline   Reply With Quote
Old 02-18-2010, 02:43 PM   #2
Rewards Points: 5,336
The blade is not aligned properly. There are instructions in the manual to align the blade. I would start with that.
Ron
Old 02-18-2010, 02:54 PM   #3
DIY staff
Rewards Points: 7,174
It sounds like Rons got it--However as long as you are tuning up the saw--make sure that the rear fences(left and right) are square to the blade and aligned with each other.--Mike--
Old 02-19-2010, 03:15 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Yep. The blade's not tracking in a straight line. Each adjustment will affect the next adjustment. Get it tracking first, then adjust the blade square to the surface of the table. Then adjust the arm so the blade tracks square to the fence.
Old 02-22-2010, 06:09 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
The easiest way to check the alignment is to use a full size Framing Square.
Turn the blade OFF when checking the alignment.
http://marketplace.hgtvpro.com/Produ...558454&From=GW
Disclaimer
& Stay Safe
.....Bob Lavery
Special saw for clean cuts in drywall / plaster jamiedolan Drywall & Plaster 7 02-02-2009 06:05 PM
Help With Radial Arm Saw EPMcGee Tools 3 03-13-2008 06:15 PM
Need a manual for my Radial arm saw dramsey64055 Tools 1 01-06-2008 10:18 AM
Radial Arm Saw Manual needed DAlnB Tools 6 11-27-2007 01:12 PM
Bad tile cuts krush Flooring 5 06-18-2007 09:15 AM
