12 Foot Header - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 09:58 PM   #1
12 foot header
Hello all. I want to remove a load bearing wall that is 12 feet long. What size lumber should I use? Would double 2x12s be enough? And do I need two jack studs on each end for support or would one be enough for that long of a span? Or would I be better off using double 12 inch lvls?
tjames64 is offline   Reply With Quote
Old 07-14-2011, 10:24 PM   #2
Rewards Points: 5,336
It would help if you described what was over this wall. Engineering a header is based upon the load it's carrying.
Ron
B. Franklin 1759
Old 07-14-2011, 10:30 PM   #3
concretemasonry's Avatar
Rewards Points: 2,608
What is the floor sytem to support the conctrated load from the ends of the lintel? - The load has to carried by something, no matter whether is a single or double jack.
Dick
concretemasonry is online now   Reply With Quote
Old 07-14-2011, 11:19 PM   #4
Well my living room, the wall, and the other room are completely gutted to the studs. I see my ceiling joists are 2x6s 16 inches apart, that run perpendicular to the wall. I have a small cape cod that is 26'x25' and the ceiling joists actually run the entire 25' of the home. My floor joists are 3x 10s of old sturdy lumber and the header I think will be resting on a floor joist. I have to double check that but the floor joists run parallel with the wall I wish to remove. And yes even though I believe its not common, my floor joists and ceiling joists do not run the same way.
Garage Header rwbil Building & Construction 11 09-16-2010 11:50 AM
Framing for Header in Basement Red Truck Remodeling 7 03-18-2010 08:11 PM
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 09:13 PM
Garage Header Insight red3908v Building & Construction 4 04-27-2008 08:55 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
