100 Year Old House Porch Roof Raising/shoring - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-13-2014, 07:41 PM   #1
thebarn61's Avatar
Rewards Points: 35
100 year old house porch roof raising/shoring
Hello,
I am getting ready to lift the front porch roof (on my avatar) to replace the decking and some frame pieces. I'm not raising much, only enough to slide the new decking under and to replace some base pieces on the columns, hopefully the columns are good. I plan to raise the porch by the lentil under the eaves (I swear it is concrete but most likely it's stucco) and brace it, but I am not sure if I should secure the roof using 2x6x16's at the lentil as well or up at the facia and soffits? Any recommendations would be greatly appreciated. Thxs
thebarn61 is offline   Reply With Quote
Old 02-13-2014, 10:27 PM   #2
Rewards Points: 14,312
Let me ramble for a min.
I've redone dozens of old porches like yours before and this is a partial list of the things you may or may not be facing so you will be ready for a plan B if you run into trouble.
The bottoms of columns rot out because there in direct contact with the decking with no drain holes, most people caulk them, worst thing you can do.
Now all the moisture has no way out.
There needs to be a pier and footing under all of the columns, it not the decking is going to sag and cause a low spot for water to pool.
Want this to be mantaince free, or are you trying to preserve it back to what it was?
There's way to keep the same look but make it not rot out ever again.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
thebarn61 (02-13-2014), Windows on Wash (02-14-2014)
Old 02-13-2014, 10:31 PM   #3
thebarn61's Avatar
Rewards Points: 35
I will be moving into the house with my wife a 2 girls so I want to do it right. Any advice will be greatly appreciated! Thanks
I also started loading more pictures of the house in my profile if that helps with my question on where I should secure my braces, soffits/facia vs lentil location
Old 02-13-2014, 10:31 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 924
Since this might involve more than roofing/siding I moved the thread for ya
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 02-13-2014, 10:39 PM   #5
thebarn61's Avatar
Rewards Points: 35
carpentry?
Old 02-13-2014, 11:03 PM   #6
Think your using the wrong term.
What you need to lift I would call a beam.
Only need to work on one column at a time, and only need to lift about 1/4 to do what you want to do.
I use a 10 ton bottle jack, A 4 X 4, and two 2 X 6's.
One 2 X 6 on the floor, bottle jack, 4 X 4, then another 2 X 6 under the beam to spread out the load.
They make 2-1/4" vinyl coated T & G composite flooring with a wood grain.
Using Simpson post bases with stand offs will keep the 4 X 4's inside that column off the decking.
Using 1 X 6 PVC lumber as a base with vinyl cove moulding to trim out the top will divert the water away from the base of the columns.
thebarn61 (02-14-2014)
Old 02-13-2014, 11:04 PM   #7
Plumber
Rewards Points: 924
Originally Posted by thebarn61 View Post
carpentry?
Carpenters are "jack of all trades" lets see what happens.
I know you've had some issues loading images but it might help if you could give us a couple pics of your lift points and areas to repair.
Old 02-13-2014, 11:39 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 802
Nail 2 2X6s to look like a T shape, you want to jack up on the same beam the columns are on.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 02-14-2014, 08:25 AM   #9
thebarn61's Avatar
Rewards Points: 35
My terms need tweaking for sure. I am planning on using a pole shore to lift the roof a 1/4 at the corner columns inside the porch frame then brace with 4X6 on the outside, beefed up bases (24x24 3/4 plywood and 2x's) with 4X6 top plate as you described. I do need to replace some of the framing due to rot as well.
My question pertains to additional braces (might be overkill) that would prevent the roof from shifting) at a 20 degree +/- angle from the ground (staked) to the soffit/facia or to the lentil? 4 in the front and 2 on the sides.
I tried to include more pictures but after the 1st one loaded I get "missing token" and can not upload more?
100 year old house porch roof raising/shoring-001.jpg
Old 02-14-2014, 08:44 AM   #10
thebarn61's Avatar
Rewards Points: 35
Here's a better picture regarding brace location
100 year old house porch roof raising/shoring-2x6x16-brace-location.jpg
Old 02-14-2014, 08:58 AM   #11
If you did it that way your jack would not be sitting under a rim joist to keep it from going down as your jacking.
And would be right where you need to be replacing the deck boards.
The only columns that are holding up the roof are the ones along the front edge, the side ones are just for looks.
And I would not feel good about now having to have 3 people to do a two man job plus having that much weight over my head while working.
I had some simple caps made up for my bottle jacks, nothing more then a piece of steel pipe about 1" long welded to a 6 X 6 1/2 thick steel plate.
When you set them on top of the piston the pipe keeps it in place and the plate keeps the top of the piston from compressing into the wood.
Old 02-14-2014, 09:05 AM   #12
In that picture you just posted the longest one would be doing nothing, if god forbid it came down it would just rip off the fascia and roof sheathing.
Here's a picture that sort of shows how that roof is likely framed.
http://www.bing.com/images/search?q=...electedIndex=1
You need to be supporting just the rim joist.
BigJim (02-14-2014)
Old 02-14-2014, 09:09 AM   #13
thebarn61's Avatar
Rewards Points: 35
I would remove the pole shore jack inside the deck frame after bracing the lentil above the columns outside of the deck frame with the 4x6 's between the 4x6 plate on the lentil and beefed up base plates
Old 02-14-2014, 09:13 AM   #14
thebarn61's Avatar
Rewards Points: 35
The large picture was for additional bracing not the support bracing just to keep it from possibly shifting.
Old 02-14-2014, 09:16 AM   #15
thebarn61's Avatar
Rewards Points: 35
Okay you answered my question on the extra supports I should definitely use the lentil not the facia/soffits I see. Like I said I probably don't need these it was just an extra precaution for any possibility of the roof shifting when I raise it
The Following User Says Thank You to thebarn61 For This Useful Post:
BigJim (02-14-2014)
Tags
100 year old house , 1914 restoration , covered porch
Adding a deck with roof (a porch) to a 1988 stick-built house Rector02 Roofing/Siding 7 10-24-2013 02:46 PM
Leaking metal porch roof and backing up into house Giraffeflute05 Roofing/Siding 4 09-29-2012 10:46 AM
Porch roof abagoz Building & Construction 0 03-17-2011 05:59 PM
missing bricks on the outside of my house above the front porch roof aredmond Building & Construction 1 10-02-2010 07:34 AM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 07:51 AM
