Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-18-2011, 09:42 AM   #1
Red face
10 ft Span how much support
I have built an extension on to my kitchen. My house is a two story. When I open the existing kitchen wall to the new section there will be a 10ft opening that needs to be supported. How many 2x8 would I need to laminate to support this span.
magate is offline   Reply With Quote
Old 05-18-2011, 02:02 PM   #2
Is your kitchen on the first floor? If so, you aren't going to be able to laminate enough 2x's together to span 10 feet. Four 2x12's together can only span a maximum of 8'4" if the house is two stories and the room width (perpendicular to the wall) is less than 20 feet. Sounds like you will need an engineered beam for your ten foot span.
There is a span table posted in this thread:
Load Bearing Wall / Additional Support Needed???
Besides, you will also have to worry about load paths to the foundation and possible new point loads.
loftezy is offline   Reply With Quote
Old 05-18-2011, 02:04 PM   #3
Thanks so much. I will review.
Tags
house addition, laminate, span
Should I build a support wall to address long span before tiling? twobyfour2 Flooring 4 05-02-2011 03:03 PM
Basement span without support? Russell8 Building & Construction 12 12-01-2010 04:23 PM
Maximum Beam Span to support a Shed Roof? rk-nc Carpentry 6 10-12-2010 09:35 PM
how to span dance floor without support columns mark4teach Building & Construction 3 11-24-2009 02:25 PM
Maximum span without intermediate support question yaryar Building & Construction 2 11-11-2008 11:08 PM
