1/4" Recoil Vs. 3/8" Straight Air Hose - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 02:07 PM   #1
Rewards Points: 1,062
1/4" recoil vs. 3/8" straight air hose
i am contemplating an acquisition of the attached 1/4" recoil air hose just because it looks less messy for jobs that don't require distance from the compressor. currently i use a 3/8" straight hose witch is a living mess because of its size and shape. but was wondering about the effect the reduced bandwidth might have on the nailer, i.e. if it will be slower or weaker?
thanks
1/4" recoil vs. 3/8" straight air hose-recoil_air_hose_x.jpg
Old 10-30-2011, 02:11 PM   #2
Experienced
Jackofall1's Avatar
Stick with the 3/8 the 1/4 kinks way to easily and you will always be pulling on it against the natural coil built into it.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
amakarevic (10-30-2011)
Old 10-30-2011, 02:28 PM   #3
jschaben
Rewards Points: 502
I agree with Mark,,, not to mention it it's stretched out very far and you have a light tool, it will take the tool away from you as soon as you lay it down.
I bought a 50ft length of 3/8 from home depot and cut it into a 20' and two 15' lengths so I can get something about the right length no matter what. You can get 3/8" barb to 1/4" pipe fittings at most any plumbing department and air fittings at almost all auto parts stores.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following User Says Thank You to jschaben For This Useful Post:
Old 10-30-2011, 02:37 PM   #4
DIY staff
Rewards Points: 7,174
I agree with every one here---skip the recoil hose-(they are only good at a work bench)
They end up a snaggled up mess in no time.
Old 10-30-2011, 04:23 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,250
coil hoses are only any real use if they are connected to a air supply that is overhead such as in a shop space. otherwise i would pick up a normal 1/4" hose before id use a 3/8 for inside work
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 10-30-2011, 04:43 PM   #6
Rewards Points: 6,652
1/4" is great when working in a workshop, and you are using it, with a bungee down the middle to attach tools, or using it in a workshop, with attachment points on the wall. Otherwise, they are a PITA to work with, when trying to do something. Way too short, and always getting tangled.
As for the short hose, it will tell you the lay when coiling back up. When unrolling it on the job, just lay it out, and give it a couple of twists in the air, to get it to lay straight.
The Following User Says Thank You to gregzoll For This Useful Post:
Sprayer hose removal zubby01 Plumbing 0 07-29-2011 12:51 PM
running extension from outside garden hose faucet denemante Plumbing 6 05-27-2011 12:18 PM
3/8" ceramic tiles over 1/4" cork over concrete ship_wreck Flooring 3 05-22-2011 12:58 PM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 12:52 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
