XP Problem - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 08-01-2009, 11:34 AM   #1
XP problem
XP has a drop-down menu to "always show,always hide/hide when inactive" on the task and start menu, that allows showing or not showing icon on tray. Drop-down does not drop down! Any ideas why, or how to get it to?
carolandfritz is offline   Reply With Quote
Old 08-02-2009, 09:45 AM   #2
On the XP task bar (the blue bar at the bottom of the screen) right click your mouse in any of the free space of the task bar, then click on Properties from the pop up menu.
Then uncheck the 'Hide Inactive Icons' check box, found at the bottom of the properties window.
Or is you wish to customize the options, keep the check box checked, and simply click on the customize button.
mikedizzle95 is offline   Reply With Quote
Old 08-02-2009, 10:18 AM   #3
Thanx, Mike! Did all that, but as I said, drop-down menu does not drop down:thus I am unable to "customize", ie hide, show, etc. Worked OK on old computer with XP.
Old 08-02-2009, 10:20 AM   #4
Are you sure the menu bar is on the bottom?
Some people accidently drag it to one side
Do you have the windows key on your keyboard to bring up the menu?
Old 08-02-2009, 10:33 AM   #5
Xp
Here's the scoop: click on task bar, properties, hide inactive icons, customize. Now "current items" is there. Drop-down menu on any item does not drop down, so I cannot change whether icon shows or not. It's no big deal, I just hate it when my computer refuses to obey me!!
Old 08-02-2009, 12:14 PM   #6
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Okay, this is a rare and tricky problem, but let's see if this fix works.
1) Right click on your desktop and click Properties.
2) When Display Properties opens, go to the Appearance Tab.
3) Click the Advanced button.
4) In the Item drop down, select Active Title Bar.
5) Now in the size setting beside Active Title bar, reduce the size and click OK to apply the settings.
Now check and see if the drop downs are accessible. For some reason this seems to fix the problem for some people.
poppameth is offline   Reply With Quote
Old 08-02-2009, 12:27 PM   #7
Well, I'll be hornswaggled! It WORKED! Go figure, who'da thunk it? Thanx, Bro. I'm gonna put you in for a raise! Fritz
Old 08-02-2009, 02:51 PM   #8
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
No problem. Not sure why that works but most of the time it does.
Old 08-02-2009, 04:12 PM   #9
How on earth did you come upon that fix?? Anyway, thanx again F
Old 08-02-2009, 05:43 PM   #10
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I ran into it once before and scoured google for a couple of hours to find the answer.
Problem with fan coil unit/hydronic system. flood1911 HVAC 2 09-05-2008 05:57 PM
2 switches , one light problem pepperthecat Electrical 2 07-08-2008 04:57 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
