Won't Accept Password - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 06-24-2012, 03:36 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 180
Won't accept password
I run an on-line forum. Like many, the admincp is double password protected. On my old Dell laptop running Vista, no problem getting in. Just bought a new Dell laptop with W7. On it the forum won't accept the 2nd password. It won't take it on my wife's new Dell with W7 either or an old desktop with XP. I have enabled both SSL, set it to accept all cookies, turned off the security. I have tried IE9, (that's what I have on the old one) Chrome and Firefox. I have copied and pasted the password and typed it in. Any ideas?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-24-2012, 05:21 PM   #2
Too Short? Cut it Again!
Sounds like their might be an encryption mismatch? Firewall problem on the forum server end? Some systems look at the ID for the actual machine as part of a security match.
Old 06-24-2012, 05:23 PM   #3
Rewards Points: 180
that's what I was wondering if it's a server problem. Forum owner doesn't think so. I turned off my firewall and it didn't help.
I hate not being able to use my new laptop. It's 8gb 1TB.
The old one was slow.
Old 06-24-2012, 05:28 PM   #4
Rewards Points: 6,652
What happens if you use another browser?
Old 06-24-2012, 05:32 PM   #5
If you can get in with one machine but not the others, the forum password scheme must be looking for some schema you cannot provide correctly. The problem would seem to be on their end or, as suggested, part of the deal is your actually machine identifier.
Old 06-24-2012, 05:33 PM   #6
Rewards Points: 180
I have tried IE9, chrome and Firefox on 3 different computers. 2 with W7 and one with XP. But I can still log in on my old one running Vista with IE9.
Old 06-24-2012, 06:07 PM   #7
Most likely a cookie or certificate that the other machine is holding on to, and the site is using that to identify the machine to the user, for authenticating. You could try a export of the cookies and certificates, then import to the new machine to see what happens.
Old 06-24-2012, 06:56 PM   #8
Rewards Points: 180
Thanks, I'll pass this on to the owners.
Old 06-25-2012, 02:40 PM   #9
Rewards Points: 180
Not a cookie. Still working on it.
Old 07-06-2012, 07:17 PM   #10
Rewards Points: 180
Don't know what happened, all of a sudden I can log in using Firefox. Still can't using IE. But at least I can access.
Old 09-08-2012, 06:26 PM   #11
jc
i don't know if this will work or not but if its a problem of not seeing the right computer. get a new email address and reregister using another user name with the new email and see if this works . at least you'll know if thats the problem .
joesconley is offline   Reply With Quote
Old 10-08-2012, 05:33 AM   #12
I think there must some problem with IE , By the way which version are you using. Try clearing all cookies and recent history. Still if you are not able to do that than update it with latest version.
Last edited by oh'mike; 10-08-2012 at 05:44 AM. Reason: Remove advertising link--please read posting rules
AlfredBailey is offline   Reply With Quote
level plywood floor to accept vinyl flooring jimmysmitts Flooring 5 02-10-2012 08:32 AM
bios password reset bignezzy74 PC Repairs & Upgrades 8 11-01-2011 11:45 AM
How do I cut off sistered joists to accept hangers tgice Building & Construction 1 01-05-2011 02:11 PM
My 125A Square D HomeLine will not accept tandem breakers brons2 Electrical 3 11-01-2010 11:49 AM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 05:04 AM
