Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 02-13-2013, 08:14 PM   #1
Jack of all Trades
lifestooshort81's Avatar
Wireless router set up as a wireless repeater
Hey folks! I sometimes have spotty wii-fi coverage out in my workshop which is over 100 feet from the wireless router in my house. So I had a thought; I have an "old" linksys wireless router I'm not using. There's nothing wrong with it other than it being a b/g wireless signal. What do I have to do to set this up as a wireless switch/repeater/booster (I'm not familiar with the proper term)??? the linksys router is a wrt54g I believe.
I'm just trying to avoid buying anything. Times are tough and if I already have on that could work why go buy one??
Al C
lifestooshort81 is offline   Reply With Quote
Old 02-13-2013, 09:49 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Connect to the router with a patch cord from your computer, Set a static IP (ie router IP is 192.168.1.1/255.255.255.0, you set your computer static IP as 192.168.1.100/255.255.255.0), then open up your favorite browser, in the address bar type in the IP of the router, log into the administration page, then turn off DHCP. If your other router you are connecting to, say is 192.168.254.1, you can set your other router with a static IP of 192.168.254.2, so you can easily access if need be later on.
After all of this is said and done, you disconnect your router that you just setup up for the DHCP off, change the Static IP setting on the computer you used, back to automatic, then shut down your other router, connect a patch cord from that one, from the LAN port, to the LAN port on the router you wish to use as an Access Point.
Turn back on the modem, let it sync to the ISP. Then turn on your router connected to the modem, let it sync with the modem. Then turn on the newly configured router as an Access Point, let it connect to the Router, then you have yourself a A/P instead of a router.
There is a lot of good networking info over at http://www.ezlan.net.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 02-14-2013, 12:28 AM   #3
Jack of all Trades
Thanks man! Worked like a charm!!! I figured it was something rather simple.
Old 02-24-2013, 10:23 AM   #4
If I understand correctly, you are suggesting linking the two routers with a LAN cable?
OP, if you want to have a true wireless repeater or if you have trouble with stability, look into updating your WRT54G with free custom firmware such as DD-WRT
http://www.dd-wrt.com/site/index
Installing the firmware is not the difficult if you follow the procedure carefully: http://www.dd-wrt.com/wiki/index.php/Installation
Then, you can easily use the second router as a wireless bridge/repeater:
http://www.dd-wrt.com/wiki/index.php/Repeater_Bridge
whiskers is offline   Reply With Quote
Old 02-24-2013, 11:26 AM   #5
gregzoll's Avatar
Whiskers, what I explained, is how you setup a router as an Access Point. The reason of connecting to the LAN vs WAN port on a router, when not running 3rd party firmware, is because you do not want to go through the NAT. Otherwise, you have to setup a Router behind router scheme, and go through a whole lot of work to get the two LAN's to talk to each other.
With DD-WRT, it is fine, but for most it is more of just a band-aid, vs. actually purchasing true AP/Bridge/Repeater equipment.
Question about wireless router close to TV Jessidog Home Theater 4 07-22-2011 08:04 AM
router problem boman47k Networking 4 04-12-2011 07:07 PM
Router Advice diyheroe Carpentry 0 09-24-2010 10:09 AM
wireless router install problems Knucklez PC Repairs & Upgrades 27 08-24-2010 09:18 AM
wireless router problems JAVAMAN PC Repairs & Upgrades 11 12-20-2008 03:50 PM
