Windows XP Wireless Driver Missing - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 08-18-2008, 12:51 PM   #1
My harddrive crashed on my laptop. After replacing the harddrive I reinstalled windows xp with the recovery disk that came with the laptop. For some reason or another the network adapter or driver was not installed. I think the problem is with the recovery disk itself. Does anyone have a suggestion for curing this issue?
toniv2326 is offline   Reply With Quote
Old 08-18-2008, 01:53 PM   #2
newer than a newbie...
Rewards Points: 87
Hi There.
Was your wireless adapter built into your computer or a USB key/device? In either case, you will likely have to download or retrieve the drivers that came with your system (possibly a CD if it was an onboard wireless device), or a CD that came with it, if it was a USB device.
If you don't have these CDs, see if you can search online for the model of your laptop and brand, and find out if there is a driver that is suitable.
I hope that helps you out.
mcvane is offline   Reply With Quote
Old 08-19-2008, 01:55 PM   #3
Yes it did. I am working again. Thank you very much for your help.
Old 08-20-2008, 09:59 AM   #4
how can you tell if u have a wireless driver/net adapter? i think that this is my problem. i have the wireless router set up and attached to the computer, but it doesn't seem to reconize it.
JAVAMAN is offline   Reply With Quote
Old 08-20-2008, 10:53 AM   #5
Most laptops built in the last few years have a built in wireless adapter, but very few desktops will have this built in. Instead if you have a desktop, you generally will have to purchase a wireless adapter.
I recommend the kind that you actually install into the computer, which involves opening the case and sliding the card in. It is pretty straightforward, but you should be careful about static. You can also buy external wireless adapters that plug into a USB slot as well, but the internal cards are better.
With that said, if your computer is next to your router, then there is no reason to use wireless. Take a Cat-5 network cable, which looks similar to a telephone cable, but is usually a little wider and has a larger plug, and plug your computer directly into the router. Wireless is nice, but you loose a lot of speed, when you compare it to a wired connection.
If you are still unsure about whether you have a wireless adabpter installed you can:
Goto: Control Panel --> System --> Select the "Hardware Tab" --> Select "Device Manager" --> and Click the arrow next to the "Network Adapters" field.
If you have a wireless adapter installed it should be listed here. If you are still unsure, check the computers manufactures site support section and find your computers specs.
Charles is offline   Reply With Quote
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
Missing Wireless Remote - Motorized Plasma TV Lift JanFan Home Theater 3 03-19-2009 08:46 AM
Dell driver missing Rafael5582 PC Repairs & Upgrades 1 08-14-2008 05:52 AM
new windows juliejules4 HVAC 12 12-06-2006 01:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
