WiFi Antenna - PC Repairs & Upgrades - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 03-01-2012, 11:50 PM   #16
Originally Posted by Ironlight View Post
I would bet also that the dishes are too large.
Given that N standard antennae are more complex than the older B and G antennae you probably did the best thing available by shielding/reflecting the existing hardware.
That may be the case. although i'm unsure just what makes the N routers have a stronger signal.
Old 03-16-2012, 02:15 AM   #17
You need a directional antenna .You can be used for point to point or some times multi point system.
pollostar is offline   Reply With Quote
Old 03-16-2012, 01:47 PM   #18
Yes, you are correct! See my post #12 for how I solved the problem!
Old 03-17-2012, 12:45 AM   #19
Rewards Points: 81
Build a cantenna for a few bucks. Works great.
Total Tool is offline   Reply With Quote
Pre-wired coaxial cable mapping & digital antenna set up BadHand Electrical 6 10-30-2011 10:37 PM
EMT as antenna mast? Ultrarunner2017 Electrical 23 05-30-2009 12:46 PM
Do I need a digital antenna? darsunt Home Theater 9 02-12-2009 12:00 PM
Grounding my new over-the-air HDTV antenna pcampbell Electrical 2 01-15-2009 12:42 PM
large outdoor antenna mcvane Home Theater 22 09-08-2008 07:26 AM
