WiFi Antenna - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 02-17-2012, 10:36 PM   #1
WiFi Antenna
I have my daughter connected to my home network!
Her house is approx. 200' away from mine.
At her end, I have a TPlink 722N (usb) connected to about 15' of coax cable, running outside to the TPLink antenna.
At my end I have a DLink N router. There is a direct line of sight, through a window, between the two.
The connection gives about 2 bars on the signal strength icon.
From time to time, if the weather isn't cooperative, it fails to connect.
I would like to install an antenna at my daughters end, that would give me a more reliable signal.
I would be interested if anybody knows of a suitable antenna for this purpose. Either manufactured or home built.
Old 02-17-2012, 11:47 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
Here is a link to a wireless booster that will work better than the high gain antennas. http://www.amazon.com/Cisco-Linksys-.../dp/B000085BD7
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-18-2012, 11:38 AM   #3
Thank you for the link! It never occured to me that electronic boosters were available.
Are thes located with the router or can they be located at the distant location also?
Old 02-18-2012, 12:22 PM   #4
bbo
also look up directional antenna
http://www.radiolabs.com/products/wi...ss-antenna.php
and for better reliability, you can hook up two wireless routers or access points as wireless bridges.
http://www.dd-wrt.com/wiki/index.php/Client_Bridged
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
BigJim (02-18-2012)
Old 02-18-2012, 02:05 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
I put the router at one PC and the booster at the other one.
Jim
Old 02-18-2012, 11:29 PM   #6
Thanks everybody for your tips. Lots of info to digest and it may take me awhile! When I make a decision and have tried it out, I'll post back!
Old 02-19-2012, 07:56 PM   #7
Too Short? Cut it Again!
URL did not work. Sorry.
Old 02-22-2012, 10:28 AM   #8
??????????????? Worked for me!
Old 02-22-2012, 11:21 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 188
It worked for me too.
Jim
Old 02-23-2012, 10:54 AM   #10
Just run an ethernet wire underground... that's what I would do.
Chaining Wifi is bound to run into frustration.
Weird_T_Figure is offline   Reply With Quote
The Following User Says Thank You to Weird_T_Figure For This Useful Post:
Hardway (02-24-2012)
Old 02-24-2012, 11:12 AM   #11
Rewards Points: 16
^ I agree.
I would just get a spool of ethernet cable and run it 6" underground, then connect it to a second router/switch for the connectivity in the second home. It will give a faster and more reliable connection for the secondary home. A signal booster is a nice alternative, but then you are ensuring that more people near your home are able to access your connection; even if it is secured, which any wireless connection should be, you want to minimize the amount of people who can be in range to see and possible access your connection.
DavesWS6 is offline   Reply With Quote
Old 02-28-2012, 08:37 PM   #12
I found a simple, workable solution to my problem.
I made reflectors from aluminum sheet stock that are mounted 1" behind the Dlink router antenna's.
I cut the aluminum into 7" squares and bent them into a curve that had the cord about 2" from the aluminum.
To mount the two reflectors I cut styrofoam blocks to fit the curve and taped these to the reflectors, centered between the top and bottom.
I drilled a hole in the blocks and slid the reflectors onto the antenna's.
Originally, the signal was a maximum of 2 bars (40%) but with the reflectors it went to 3 bars (60%) and now connects reliably.
Total cost=$0
Old 02-29-2012, 08:05 AM   #13
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Total cost=$0
You must be an antennologist to think of something like this.
Amazing that it helps.
titanoman is offline   Reply With Quote
Old 02-29-2012, 01:40 PM   #14
I've been tinkering with using surplus satellite TV dishes for wifi, but had little success. With these I had to run coax outside to a dish and although they did work, the dishes weren't an improvement over the router antenna's. probably because of the cable loses.
With the antenna reflectors, there is no concern about cabling.
Old 03-01-2012, 11:24 PM   #15
Ironlight's Avatar
I would bet also that the dishes are too large.
Given that N standard antennae are more complex than the older B and G antennae you probably did the best thing available by shielding/reflecting the existing hardware.
Ironlight is offline   Reply With Quote
Pre-wired coaxial cable mapping & digital antenna set up BadHand Electrical 6 10-30-2011 10:37 PM
EMT as antenna mast? Ultrarunner2017 Electrical 23 05-30-2009 12:46 PM
Do I need a digital antenna? darsunt Home Theater 9 02-12-2009 12:00 PM
Grounding my new over-the-air HDTV antenna pcampbell Electrical 2 01-15-2009 12:42 PM
large outdoor antenna mcvane Home Theater 22 09-08-2008 07:26 AM
