Originally Posted by sdsester
Is your web browser set to default print to something other than your printer?
This would be my inclination as well.
If you go to your start menu, go to "printers and Faxes" or "devices and printers" if you have it and make sure the printer you want things to print to has a check mark on/next to it, if not then right click on that printer and select "set as default."
When you go to "file" and print on your web browser a box will pop up and at teh top of that box is where you can select what printer you are printing to, make sure that printer matches the one you just set as default.
