Vista Sp1 Won't Load. Drive Won't Restore - PC Repairs & Upgrades - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 11-24-2008, 02:25 PM   #31
The HP recovery disks can not do a full install, they can only repair or restore the Vista software that came pre-installed by HP. This is probably why the ATA drive won't work using the HP recovery disk and also why you shouldn't reformat the SATA drive that has Vista installed on it by HP.
So if i'm understanding this right..... even if I get a new SATA drive the recovery discs won't install the full Windows and the factory software load.
sv9779 is offline   Reply With Quote
Old 11-24-2008, 02:29 PM   #32
Not always, alot of discs ive seen come with the os. Can you boot from the disc?
If all else fails, don't go vista (unless you have something fancy...like tri or quad sli, etc. that wont work with xp...)
rgsgww is offline   Reply With Quote
Old 11-24-2008, 02:44 PM   #33
the Musigician
DangerMouse's Avatar
the recovery IS the os cd. it will install to new HDD. rgsgww is right. although sometimes there is another cd or more with drivers needed as well.
"If all else fails, don't go vista (unless you have something fancy...like tri or quad sli, etc. that wont work with xp...)" agreed, although my kid wants to play halo2 which, of course, needs it...... here we go again......
DM
Old 11-24-2008, 07:45 PM   #34
Think I'll send HP tech support an email and ask them what my discs are.
Old 11-24-2008, 08:43 PM   #35
DM
Haha, yeah I wish quad sli worked with xp...Windows vista x64 is not very good...Lockups, etc. updated alot of things. Some people said to change volts on the mobo, cpu, ram. No way, Im not going to fry my qx9650.
Old 11-25-2008, 06:15 AM   #36
the Musigician
vista... heh...... windblows "Longhorn" was better! and THAT took me all day to repair all the bugs before it'd work.
same thing with XPCP, but i use it now that i fixed it....
DM
Old 11-25-2008, 07:20 AM   #37
DM
Linux is way more stable...but I can't play any of my games! wine doesn't do anything for my games...
Right now I have a triple boot with ubuntu 8.10 x64,vista x64, and xp x86
Old 01-10-2009, 09:10 PM   #38
Just an update on my problem. I bought a new hard drive and installed it. The restore discs worked just fine. I loaded everything up and put the old drive back in to start copying my data. I decided to do a virus scan with the new McAfee's I downloaded from AT&T. (they give it to you free with the DSL service) I had done several scans with the Norton that was on the old drive. The McAfee's came up with a program that was called "pup-x" It said it may have been installed with a program or could be malicious. I had nothing to loose so I had the virus program delete it. After that I put that drive back as the master and tried the restore discs again. They worked! Updates worked again. Things seem to be fixed. Im going to leave the new drive in place and start over anyway, but nice to know it wasn't a hardware problem.
Anyway, Thanks to all for your help.
Have a great New Year
Steve
Old 01-10-2009, 09:28 PM   #39
Steve
A virus? must have been pretty malicious.
Old 01-10-2009, 10:06 PM   #40
Here is what is says about it.
Generic PUP.x
By: [COLOR=#f26522! important][COLOR=#f26522! important]webmaster[/COLOR][/COLOR] | Under: Unwanted Programs 4 Jul
Generic PUP.x is a generic detection used to identify malicious files or Potentially Unwanted Program that promotes unpopular or useless and counterfeit security programs.
Aliases:
Risk Level: Low
File Size: Varies
Affected [COLOR=#f26522! important][COLOR=#f26522! important]System[/COLOR][/COLOR]: Windows
Common Symptoms:
1. Security pop-ups or security [COLOR=#f26522! important][COLOR=#f26522! important]applications[/COLOR][/COLOR] installed without users intervention.
Old 01-11-2009, 04:48 AM   #41
crawdoogie's Avatar
Glad to hear that you figured out what was causing your problems and thanks for updating this thread as it will help others that have problems similar to yours.
The lesson here is that no single security program will detect every threat out there. So it's a good idea to run other A/V, anti-malware, security programs at times especially if you are having problems. Trend Micro and Panda and others have on-line scanners that work well as a second opinion to your installed apps.
And take a look at Threatfire. It works differently that other AV software as it detects malicious behavior and doesn't depend on virus signature files like many other AV apps. It is very light on system resources and work alongside you regular AV.
http://www.threatfire.com/
crawdoogie is offline   Reply With Quote
Old 01-11-2009, 05:37 AM   #42
the Musigician
good post crawdoogie, i should mention another great freeware here---> www.avast.com
DM
Old 01-11-2009, 10:36 AM   #43
Thanks for the info. I just downloaded Threatfire and about to start a system scan.
Another VISTA O/S question YerDugliness PC Repairs & Upgrades 11 12-04-2008 07:13 AM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Load Calculation ? RM575 HVAC 9 07-04-2007 12:37 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 08:10 AM
