If your computer runs from the hard disk then the disk is probably fine. Don't send the PC into HP, you "have a 5 yr warranty at the store you bought it from.", take it there. If they can't fix it then it's their responsibility to send it out on their dime. Ask them what procedures/protocols do they follow to diagnose/ repair systems under warranty. You should also read the warranty as well so you know what is expected of them.
Some things that you can do:
1. uninstall any third party firewalls or turn off windows firewall if thats what your using. reboot
2.Take a look at this HP website and follow directions to get restore to work or do a full system recovery.
http://h10025.www1.hp.com/ewfrf/wc/d...0850095&dlc=en
3. Run Disk Clean UP. See
http://windowshelp.microsoft.com/Win...139d91033.mspx
In the
Disk Cleanup Options check all files
In the
Disk Cleanup: Drive Selection select drive usually "C"
In the
Disk Clean up tab select everything
except "compress old files" if shown
In the
More Options tab:Programs and Features uninstall any programs that you don't use.
4.Run System File Checker. For more info go here:
http://vistasupport.mvps.org/system_file_checker.htm
5. Run Checkdisk .
http://windowshelp.microsoft.com/Win...41f811033.mspx
6. It's very likely that virii or spyware is causing the problem.
Download and run SuperAntiSpyware free edition here:
http://www.superantispyware.com/download.html
and Malwarebytes Anti-malware
http://www.majorgeeks.com/download5756.html
It say $25 but that's if you want to buy the real time protection using it as an on demand scanner is free.
If any of the above freeze reboot the PC (alt-ctrl-del) or hold the power button down for 5 seconds.
Post back with updates on your progress (or lack of )
Other thoughts:
-is system restore service enabled?
-drive full
-loose SATA/IDE cable
-any error codes
-look in event viewer
-enable adminstrative access to run system utilities like Restore
-do a HP System Recovery as a last resort. HP System Recovery restores the entire software configuration back to way it originally came from the factory.You will have to reload all updates and software installed after initial start up.
