Video Card For 3 Monitors - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 12-28-2013, 09:18 PM   #1
Rewards Points: 99
Video card for 3 monitors
I'm installing Flight Simulator on my PC and I plan to use 3 monitors. Looks like ill need to install a video card that will support all 3. Is this something I can do myself that knows little about computer hardware or should I bring someone in like the 12 year old next door?
Thanks!
kirwinjd is offline   Reply With Quote
Old 12-30-2013, 01:55 PM   #2
Rewards Points: 2,238
Whether you can or can't depends on some things -
What your computer/motherboard will support -
What the video-card will support -
Your Operating System.....
rossfingal is offline   Reply With Quote
Old 01-05-2014, 10:14 AM   #3
RustPicker's Avatar
Rewards Points: 14
Wow, I haven't looked into a hardware comparability question like this in at least 10 years....
However, me going back to riding motorcycle(s) bump that part of my hobby as well as career.
That being said... If I would need a source to research even the
Potential..... Here's where I'd go.... Especially for any "Gaming," Graphics or CAD related question...
http://www.maximumpc.com
Do a search, I believe your answer will be obtainable.
Regards,
RustPicker - Sent from my iPad using DIY Forum
RustPicker is offline   Reply With Quote
The Following User Says Thank You to RustPicker For This Useful Post:
kirwinjd (01-07-2014)
Old 01-05-2014, 11:52 AM   #4
raylo32's Avatar
Rewards Points: 1,240
Something like this should work as long as you have a PCI Express slot and DVI monitors. They probably also make higher end models...
http://www.newegg.com/Product/Produc...82E16814129181
Live long and prosper.
raylo32 is online now   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
Old 01-05-2014, 09:03 PM   #5
RustPicker's Avatar
Rewards Points: 14
Raylo,
That's an awesome product, with a killer price point!
My reservation are the four analog monitor hook-ups vice DVI.
How much more $ would a card like that cost?
Regards,
Old 01-07-2014, 12:06 AM   #6
Rewards Points: 99
Thanks. As it turns out, my 7 year old PC can't even load the software. Ill need to replace entire desktop with a monster graphics card
Old 01-07-2014, 06:03 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,154
If you really want a wazu setup....get out the credit card.
Do a search on gaming computers. You will see lots of info on how to build a wazu setup.
One piece of advice....go with a SSD and a HD. I'm building up a HTPC right now....my boot time from POST to Win7 Log on is 7 seconds.
Old 01-07-2014, 12:00 PM   #8
Rather than spend $1000 on 1 video card with 3 DVI outputs, just run dual graphics cards.
Obviously you'll want to make sure your rig is built to handle the load/heat/etc. but I bet it would be cheaper (and more common, so easier to find support info).
AJPLeBlanc is offline   Reply With Quote
Old 01-07-2014, 12:18 PM   #9
JOATMON
ddawg16's Avatar
Originally Posted by AJPLeBlanc
Rather than spend $1000 on 1 video card with 3 DVI outputs, just run dual graphics cards. Obviously you'll want to make sure your rig is built to handle the load/heat/etc. but I bet it would be cheaper (and more common, so easier to find support info).
Did you read the op's comment that his current computer won't even load the SW?
Old 01-07-2014, 01:12 PM   #10
Yup, my comment was pertinent even if the OP is building/buying a new machine. It's more cost effective to install 2 graphics cards than it is to use 1 with more than 2 outputs.
Old 01-07-2014, 01:57 PM   #11
JOATMON
ddawg16's Avatar
What good are the graphics cards if the software won't work?
Old 01-07-2014, 02:19 PM   #12
If he's getting a new machine, one that would be able to run the software, I was saying that in that new machine that having dual graphics cards is a better approach. I was making a general statement about graphics cards, regardless of the application. Obviously I wouldn't recommend that someone install new hardware in a machine that wouldn't run the software in the first place.
Old 01-08-2014, 11:16 PM   #13
Rewards Points: 99
Thanks guys for all your input. Still looking at PC's with a graphics card to run the latest MS flight Simulator. That's why I wanted 3 monitors and maybe at some point going with projectors. I was thinking about custom ordering a Dell. That way I can hand pick everything from the OS to the video cards, HD etc.
Old 01-09-2014, 03:25 AM   #14
JOATMON
ddawg16's Avatar
NewEgg.....more bang for the buck
Old 01-09-2014, 08:50 AM   #15
If you feel comfortable building it yourself, you can check out a multitude of different resources on the web for suggestions. I'm partial to http://www.maximumpc.com/ but there are many others. Back in the day, you could save a LOT of money by sourcing your own parts and building a PC yourself. It's less prevalent today, however the exception is when building high performance PC's. You can save some money AND get better performance AND get exactly what you want.
I like Dell for everyday machines, but if you want to do stuff like overclocking, and tweaking, the Dell uses a proprietary BIOS that doesn't usually offer much flexibility.
Just things to keep in mind.
Looking to upgrade video card into the 'Diablo 3' range. Any suggestions? GordCooper PC Repairs & Upgrades 3 04-10-2012 08:48 PM
video card question Cuwillis PC Repairs & Upgrades 10 08-01-2008 07:08 PM
Need help installing a video card! xsnrgman PC Repairs & Upgrades 1 03-03-2008 10:33 AM
Is a video card the answer? Barry Spice PC Repairs & Upgrades 3 11-16-2007 04:54 PM
