Vacuum Out Your PC - PC Repairs & Upgrades - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 07-22-2010, 09:18 AM   #16
Originally Posted by Scuba_Dave View Post
Been vac'ing out thousands of PC's for 20 years more or less
Never a problem
Yeah, but even if you win a few rounds of Russian roulette, you should move onto a nerf gun, instead of a real one. can of air 5 dollars, new computer 400-a few grand. You got lucky, probably used the same type of vacuum?
L4nce0 is offline   Reply With Quote
Old 07-22-2010, 09:26 AM   #17
Same vacuum over 20 years at multiple sites ?
No
Lucky....with the same method on thousands of computers?
Just a plain old small house vac at some sites
Never spent a couple grand on a new computer - at least not these days
When memory was $500 a meg it was easy enough to do
Old 07-22-2010, 11:27 AM   #18
I wish I could say that. I just got a 1200 upgrade (2 graphic card, hdd and keyboard..) adds up when your an enthusiast.
Old 07-24-2010, 03:28 PM   #19
Tizzer's Avatar
Rewards Points: 460
I've never thought of using a vac before. I do use the vac's hose attachment for the keyboard and around the tower.
Right around the first of summer, I could hear the fan working harder than usual so I did a cleanout. Used bottled air and plain cleaning wipes on the fans. Got it up off the floor this time after I finished..... runs like a champ now, even in this dreadful heat here.
Tizzer is offline   Reply With Quote
Old 07-24-2010, 03:58 PM   #20
I picked up a computer when I visited a friend
There neighbor was getting rid of it....kept locking up
I always needed parts...so I took it
There was dog hair everywhere
I vac'd it out...ran fine
It must have been overheating
That was a few years ago...it was a P4 1.7g...fairly fast at the time
Still had all their documents & everything else on it
Old 08-25-2010, 12:35 AM   #21
Mr.
I use an air compressor to clean off my laptop. While the vacuum cleaner may work fine, the air compressor's better at removing stuck-up dirt in hard to reach places.
timothytaylor is offline   Reply With Quote
Old 09-16-2010, 11:45 AM   #22
Citrix & Cisco Ops
I don't even use a can of air. Air compressor rules out liquid.
Vacuuming, though admittedly unlikely to blow away a PC, is extremely bad practice. I put it in the same ballpark as working without a grounding strap.
When working on PC hardware that doesn't belong to you, you are supposed to reduce the risk of transferring static electricity in your work space - not add to it.
RedHelix is offline   Reply With Quote
Old 09-16-2010, 02:32 PM   #23
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
This is my tools of trade when cleaning out PCs, no issues so far.
I do want to get a filter for the compressor though. If I use it for too long it does start to spray water, but it's a very fine mist that is not really enough to cause issues, but I still stop when it hits that point.
Old 09-16-2010, 11:54 PM   #24
Rewards Points: 518
I started working with/on computers 17 years ago. The only time I actually wore a grounding strap was in college because we had to. I've "static" shocked circuit boards and other components many times(very common in a dry Canadian winter), as well as vacuumed many towers and monitors out with regular old vacuums like a Kenmore. I have never ruined anything to date. I think this is a job for myth busters.
n0c7 is offline   Reply With Quote
Old 09-17-2010, 05:54 AM   #25
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Same here. Never used a static strap and never had any issues. Just don't work on carpet and you shouldn't build up much static anyway. If I built my own computer shop I'd use ESD tile on the workroom floor to absorb static as soon as you set foot in the room. Straps just make it difficult to work in side the PC since you are dragging a wire around with you.
poppameth is offline   Reply With Quote
Old 09-17-2010, 09:09 AM   #26
Citrix & Cisco Ops
For a number of years I was a factory-authorized technician for Gateway, HP and Toshiba for a large electronics company. During the wintertime, I had seasonal employees zap RAM modules and processors on a number of occasions when they were unstrapped. One guy even killed the controller board on a hard drive. There's no myth to it.
Currently I work as a sysadmin, and even though it's a minor annoyance and our layout severely inhibits static, I always strap in before cracking open a $15,000 HP Blade.
The point is, even if the probability is extremely low, if you do screw up and zap something to death, the liability falls squarely on your lap. In PC repair it can get you sued, and in Systems Administration it can get you fired - then sued.
Inducer Vacuum Problem RobertCan HVAC 21 12-22-2009 03:20 PM
Vacuum relief valve? walker44 Plumbing 10 08-30-2009 04:33 PM
Watts Vacuum Breaker goochman Plumbing 2 06-28-2009 02:32 PM
lights dimming when using the vacuum farmerde Electrical 21 12-08-2008 08:09 AM
Big power hog- the vacuum fw2007 Electrical 2 08-06-2008 11:19 PM
