#1 |
USB CAmera
I have a small, cheap USB camera which I purchased 2 years ago for the "heck" of it. It worked fine on my last PC with Windows XP but it will not work with my new Windows 7 PC.
The computer recognizes it, says it is installed and working properly but there is no way to see an image from it.I know others have had these problems with USB cams and Windows 7 but nobody seems to have an answer. PLease point me in the right direction.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#2 | |
USB CAmeraQuote:
#3 |
USB CAmera
Yep...cheap. And stress isn't the issue. I want to know why it doesn't work. Windows 7 says it works properly, it finds and downloads the software and it appears on the computer device menu. And it works fine on the XP computers I still have. Throwing it out doesn't seem like any answer.
#4 |
USB CAmera
Is your Windows 7 machine 64-bit by chance? And all the other machines the camera works on are 32-bit or lower?
64-bit machines cannot handle legacy code (e.g. 8-bit strings) that work fine on 32-bit and lower machines. Just my guess. It is not W7's fault. It is recognizing the device. It is a software/driver compatibility problem at the chipset level. No fix for it but to rewrite the code and strip out the legacy stuff. Have you double checked and searched yourself for a new driver? Try [camera name] drivers in Google directly.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by sdsester; 08-31-2012 at 07:57 AM. |
#5 | |
USB CAmeraQuote:
950Mhz WinXP Pro(32-bit) 1GB RAM Now, My new computer is: 2.90Ghz Win7 Pro(64-bit) 4GB RAM It works fine on my Win7 system. Which means that, the coding allowed for upgrading from a 32-bit OS, to a 64-bit OS. Since you have upgraded the drivers', ask the company's tech support people. |
| Display Modes | |
| Kodak EasyShare M530 digital camera issue | proofer | Off Topic | 4 | 11-18-2011 04:26 PM |
| Toilet camera stuck 25 feet underground. | theglove89 | Plumbing | 22 | 08-07-2011 07:48 AM |
| Making a waterproof/weatherproof enclosures for a network camera & its power hub | snowfall | Building & Construction | 0 | 05-02-2011 11:14 AM |
| Camera battery chargers | Jeeper1970 | General Discussion | 4 | 12-29-2008 09:16 AM |
