-   PC Repairs & Upgrades (http://www.diychatroom.com/f13/)
-   -   USB CAmera (http://www.diychatroom.com/f13/usb-camera-155253/)
Missouri Bound 08-29-2012 09:09 PM
USB CAmera
I have a small, cheap USB camera which I purchased 2 years ago for the "heck" of it. It worked fine on my last PC with Windows XP but it will not work with my new Windows 7 PC. :furious: The computer recognizes it, says it is installed and working properly but there is no way to see an image from it.
I know others have had these problems with USB cams and Windows 7 but nobody seems to have an answer. PLease point me in the right direction.
MT Stringer 08-29-2012 10:47 PM
Throw it away and get one that works with Win7. Stress will be over and done with. :-) You did say it was cheap, right?
Missouri Bound 08-29-2012 10:56 PM
Yep...cheap. And stress isn't the issue. I want to know why it doesn't work. Windows 7 says it works properly, it finds and downloads the software and it appears on the computer device menu. And it works fine on the XP computers I still have. Throwing it out doesn't seem like any answer.:whistling2:
user1007 08-31-2012 07:51 AM
Is your Windows 7 machine 64-bit by chance? And all the other machines the camera works on are 32-bit or lower?
64-bit machines cannot handle legacy code (e.g. 8-bit strings) that work fine on 32-bit and lower machines.
Just my guess. It is not W7's fault. It is recognizing the device. It is a software/driver compatibility problem at the chipset level.
No fix for it but to rewrite the code and strip out the legacy stuff. Have you double checked and searched yourself for a new driver?
Try [camera name] drivers in Google directly.
Chris0516 10-03-2012 04:13 PM
I second what was said above. As far as the difference in the code. Because I bought a Canon A630 in 2006(back when 6/8MP was the best on the market). It worked fine on my XP Pro system. At the time, my computer was:
950Mhz
WinXP Pro(32-bit)
1GB RAM
Now, My new computer is:
2.90Ghz
Win7 Pro(64-bit)
4GB RAM
It works fine on my Win7 system.
Which means that, the coding allowed for upgrading from a 32-bit OS, to a 64-bit OS.
Since you have upgraded the drivers', ask the company's tech support people.
