Types Of Cat 5 - PC Repairs & Upgrades - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 01-04-2009, 07:48 PM   #16
If you do run phone, to save money I would just run a 4 wire flat 18 awg solid phone cable there. If its just telephone, no need for twisted pair.
rgsgww is offline   Reply With Quote
Old 01-04-2009, 07:54 PM   #17
Safe, Most of the Time!!
brokenknee's Avatar
I had the phone company run the line when they did my house. So I already have a phone out there. The wife loves it, she will call me from her cell phone to bother me when ever I seem to be really busy.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 01-04-2009, 08:05 PM   #18
Geek for Hire
Rasputin's Avatar
Originally Posted by brokenknee View Post
In my case the labor is free, it is the material that cost.
Hey Rasputin, you a history buff or just want to be associated with someone that was more than a little weird?
It's my fraternity nickname because I look like him. Rasputin got a bum rap.
Rasputin is offline   Reply With Quote
Old 01-04-2009, 08:17 PM   #19
brokenknee's Avatar
I should have thought it would be something like that. Screen names can be interesting.
Old 01-04-2009, 09:46 PM   #20
Rewards Points: 502
I was doing a little more research on the direct burial cat 5e. In an old forum (2002?) on another board it was suggested that you use direct burial even inside conduit. The claim was the moisture in the lines could effect the regular cable?
I also seen there is two different types of direct burial, foil wrapped and gel filled. Is one preferred over the other? It did not seam there was much if any cost difference between the two.
Just to clarify, I can run one cable, connect a router, then run two separate computers off that (either wired or wireless)? The cable to the shed would run back to the router in the house.
All conduit will get water in it at some point in time, so you need to run cable rated to be submerged. I have run regular cat5 in conduit and within a few years it had to be replaced due to water penetration.
In your case, I would run direct burial cat5 (gel filled) in conduit to your location. (I have done the same thing before and will be doing it again this spring to my 40x68 shop).
Yes, you only need one cable between the house and the shop. You can terminate it into a switch/router and share as many network devices (PCs) as you wish in the workshop. if you setup a wireless router out there you will need to put it in gateway mode.
As others have said, run at least two cables...and maybe even an RG6 coax...in case you want to extend cable out there or put a security camera in.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-05-2009, 04:56 AM   #21
brokenknee's Avatar
Thank you,
I will run an RG6 out there for satellite TV. That is one thing I did not think of. Maybe I will pull two cat5 cables out there.
I am going to check the price difference between regular and direct burial. Even though my labor is free, it is something I would prefer not to have to do twice.
Old 01-05-2009, 08:51 AM   #22
Geek for Hire
Rasputin's Avatar
Thank you,
Gel-filled is good stuff. Most of our large cable runs (50 and 100 pair) that are direct bury are gel filled. It just makes a nasty mess when you're terminating it. Bring lots of paper towels.
Old 01-05-2009, 11:30 AM   #23
Use some gel filled cat 5e, and gel filled rg/6.
Make sure the splices are not exposed to sun, don't want that gel oozing out of the connections!
Old 01-05-2009, 06:59 PM   #24
Rewards Points: 12
You might want to ground your termination points also. Grounding your cat5 and RG-6 is a good thing at both ends
JMATT01 is offline   Reply With Quote
Old 01-05-2009, 07:27 PM   #25
I take issue with this, as a ground at both ends of communications cable allows longitudinal noise to travel. At one time I spent more than two months removing grounds at one end of cables, when I worked for the telco!
Old 01-05-2009, 07:41 PM   #26
brokenknee's Avatar
How would one go about grounding the Cat5 and the RG6? Is there a separate ground wire that runs with them?
I have not worked with Cat5 before but I have run some RG6 and did not see an additional wire to ground it.
Old 01-05-2009, 08:17 PM   #27
Geek for Hire
Rasputin's Avatar
Seconded. You don't ground the cable, you ground the equipment rack. In your case, it's a home installation so it's totally unneeded.
Old 01-05-2009, 08:24 PM   #28
brokenknee's Avatar
So I do not even need one ground then?
Old 01-05-2009, 08:30 PM   #29
Geek for Hire
Rasputin's Avatar
Grounds and lightning protection aren't used on the cable. In my experience transient voltage will travel down the cable and knock out equipment when the rack is grounded...we had several bad lighting strikes summer of 2001, knocked out 5 dorms because the strike traveled through and into the equipment, but the cable run itself was fine. Literally fried about $40,000 worth of gear (3Com Superstack-II 1100s).
The only time I've ever had to have cable replaced is when it's too brittle from exposure to the elements (like in attics, etc) and a pair cracks enough to prevent connection. Then I whip out my Fluke and call the warranty contractor.
Old 01-05-2009, 08:49 PM   #30
brokenknee's Avatar
Use solid gel filled run in conduit, grounding not necessary, run more wire than you think you need, no splicing, no connections exposed to the sun, can use router to act as gateway to run more than one device, run rg6 for satellite TV.
Did I miss anything?
What types of wood is used in your area? bluefitness Building & Construction 7 12-21-2008 11:16 PM
Different types of hardwood Daggerhart Flooring 6 06-15-2008 09:33 AM
Code question regarding AFCI combination types and the 2005 NEC MattOverMinder Electrical 2 12-14-2007 04:10 PM
Types of Earwigs and features of Earwigs Pholma Pris Pest Control 4 11-20-2007 06:19 PM
