-   PC Repairs & Upgrades (http://www.diychatroom.com/f13/)
-   -   troubleshooting new sound card (http://www.diychatroom.com/f13/troubleshooting-new-sound-card-75591/)
voltz 07-06-2010 11:22 PM
installed new sound card because the motherboard sound card was no good. the new sound card does not work. I disabled the bios on the motherboard for the sound card but the system still does not see the new sound card. In the device manager it does not see the sound card in audio help!!
poppameth 07-07-2010 05:46 AM
Give some details on the new card and your computer please.
voltz 07-07-2010 01:37 PM
new sound card is a
Diamond Xtreme Sound 5.1 that goes into slot
works off of my windows XP
if I go into sounds and audio device properties, Audio, sound playback doesn't have the new default device listed, but the sound recording has the new device listed as the default device
poppameth 07-08-2010 05:19 AM
Have you tried installing the latest drivers?
http://www.diamondmm.com/XS51.php
Click on the Support tab and it should be the first download.
Reviews on that card aren't exactly great either. Sounds like a lot of people have numerous problems with it.
voltz 07-09-2010 01:43 AM
I tried that, but thanks for the suggestion.
poppameth 07-09-2010 05:53 AM
Is there another vacant PCI slot you can move it to? If so try that. If that doesn't work, I'm not sure what to tell you. Sounds like either the card or the drivers have some problems.
Fox 07-10-2010 04:33 PM
I'm curious to know if that fixes it now, as it was what I'd recommend. Resetting the ESCD is the only other trick I'd recommend (in BIOS) but most systems don't use that anymore.
mwha1389 07-10-2010 09:38 PM
I have had sound cards not to work and used a pencil eraser to erase on the contacts on each side. And that has worked on a couple of cards I have worked on. Of course you may want to check with the makers of your mother board to make sure you don't have something that is conflicting with it..
L4nce0 07-21-2010 11:43 PM
I would... not advice that... Soundcards are tricky beasts, by far the most killed item in my years.. that or ram.
Algorithm for trouble shooting
install drivers
try another slot.
safe mode, drivers ( for kicks)
test on second computer ( if fails, bad card)
after that look for beta drivers, and try a second card and see if it works.
oh and seriously make sure you don't have any real tech drivers, or any other sound card. that would defiantly do it.
DangerMouse 07-25-2010 10:32 AM
I've seen MBs that you had to pull (or was it add?) a jumper pin to be able to use (or not use) the onboard audio.
Or try going into safe mode and remove all drivers for audio.
DM
Scuba_Dave 07-25-2010 11:16 AM
I have had sound cards not to work and used a pencil eraser to erase on the contacts on each side. ..
I've done the same thing many times
Usually on older cards
Ther ecan be oxidation build up on unused slots
So sometimes sliding the card in & out of the slot - with power off - will make a better connection
