Transfering some stuff from old computer to new computer
I need help. First off, I don't know computers. With that said, I just bought another computer. But what I need to do is to transfer some information (2009 TurboTax files, word processing documents, some pictures, etc.). How would you go about it? Do you somehow transfer this information from the old computer to a disk, and then from disk to new computer? Someone mentioned a flashdrive. What is the EASIEST way to transfer data from an old computer to a new computer?
i use a usb memory stick, you can get them cheap from target best buy , any electronic store:thumbsup:
Essentially the same thing. I used 2G my last xfer...That is the easiest way to do it IMHO!!!
Good luck! |
with the memory stick, all you do is send your programing to the memory stick via computer on the menu start
So I plug in the memory stick, and then I go to "Start" at the lower left-hand corner, and it asks me what I want to save?
yes go to start then to computer and when you have the stick plugged into the usb port it will show the unit that you plugged in ,then send the info to the stick by right clicking your program and send to whatever the stick is called on your pc
Thanks for everyones' help. I'll be giving it a try soon, and I'll be sure to let you know how it goes. Until yesterday, I thought we'd be using the 5 1/4" floppy disks that I last remembered.
I ended up getting an 8 GB flashdrive. Actually, it was easier than I had imagined. Thanks for helping out, as I've never heard of a flashdrive or a memory stick before.
just as long as you figured everything out all is good glad i could help :thumbsup:
| All times are GMT -4. The time now is 10:27 PM. |
