Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 03-30-2007, 03:09 PM   #1
test new power supply?
I just got a new power supply, Antec 500w, highly recommended. Now I think the thing doesn't work.
Does anyone know how to test it properly? So I know whether to ask the supplier for a replacement.
darsunt is offline   Reply With Quote
Old 03-31-2007, 10:42 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
There are testing units made to test power supplies. Most if not hooked up to the motherboard, will not even work.
Old 03-31-2007, 11:10 PM   #3
Antec makes a power supply tester that I bought for < $20 at Office Depot, of all places. Here's a link to it on the Antec site:
http://www.antec.com/us/productDetails.php?ProdID=77203
Note that if you're trying to run your PSU without first connecting to the motherboard, it probably won't even start up. I forget the details, but ATX PSUs require a smallish load to start up. The tester provides that load, but it gets quite hot if left connected for long periods of time.
tima2381 is offline   Reply With Quote
Old 04-03-2007, 11:01 PM   #4
Thanks. If that is the problem, that is good news. I just bought the damn thing for $85 bucks.
Old 04-04-2007, 12:44 AM   #5
a trick any good pc-tech knows:
You can manually turn a PSU on by shorting the GREEN wire to any black. The supply needs to see a load though, so be sure to plug in a hard drive or cd-rom.
9 times out of 10 the supply is not the problem, and this trick will rule it out (if it turns on )
elementx440 is offline   Reply With Quote
Old 04-06-2007, 12:41 PM   #6
Thanks. Now I know at least the PSU runs.
Old 09-08-2007, 04:12 PM   #7
I've got a similar PSU and love it. 500W Antec Earthwatts. It's quiet, and powerful...I assume, I haven't actually tested anything. But I'm quite happy. I got it and an Antec Sonata II case (which I also like) for 100 bucks.
/crap, replying to old threads here..sorry about that.
cambie is offline   Reply With Quote
Old 09-08-2007, 08:03 PM   #8
I've assembled the computer. I'm glad I got this power supply because I keep upgrading the box - sound card, video card, 500 G hard drive - I don't know when it will end. But since I got a solid and plentiful power supply, that's one less thing to worry about.
Old 09-08-2007, 08:04 PM   #9
poppameth
Guest
Posts: n/a
This part of the forum moves a bit slow. On a related note, several months ago Antec had some major quality control issues. I'm not sure if that has been sorted out yet. I stopped buying them at the time and switches to FSP.
Need a new power supply Alan PC Repairs & Upgrades 18 06-15-2007 01:57 AM
Turning main power supply off from the meter amakarevic Electrical 2 05-22-2007 11:33 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
