Stretched Screen - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 03-01-2008, 11:36 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Stretched screen
I recently acquired a monitor that is horizontal, and the pictures and print look stretched horizontally.
Is there a way that I can reduce that horizontal look?
I have tried many things but nothing seems to work.
Or am I basically stuck with stretched pictures.
yummy mummy is offline   Reply With Quote
Old 03-01-2008, 01:09 PM   #2
Remodeler
MinConst's Avatar
The video driver might have some adjustments. I don't know what OS you but go to display properties. In windows XP its a right click on the desktop, Vista same and most older version. You might find some adjustments in there. You may also have the display set to a standard monitor instead of a wide screen. Also you may need drivers for the monitor. Look up the manufacturer's site and see what is available.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 03-01-2008, 05:48 PM   #3
Thanks Minconst. I will try that.
Old 03-02-2008, 12:20 PM   #4
Guest
Guest
Posts: n/a
I'm assuming by horizontal you mean a Widescreen monitor. If your monitor settings don't have an option for widescreen resolutions you'll have to download the latest drivers for your Video card and hope the card itself will support it along with the new drivers.
Old 04-11-2008, 09:20 AM   #5
One Hand Handy Man
It seems like there should be options on your monitor itself to adjust the picture. Do you have an older CRT monitor by chance?
ToolMan6802 is offline   Reply With Quote
Old 04-11-2008, 09:54 AM   #6
Thanks toolman. I did figure out that my computer is a much older one and does not have the capability of doing what I want it to do.
This is what I was told.
Old 04-18-2008, 03:41 PM   #7
weekend warrior
Hobb3s's Avatar
Hi, whether your computer will do it or not is often a function of the video card or built in video adapter. One way you can check to see if you have a compatible setting is to right click on your desktop background and select properties. then click on settings. You should see a screen with a picture of a monitor and a sliding bar in the bottom left labeled Screen resolution.
You'll notice it's probably set at something like 800 by 600 or 1024 by 768.
If you move that bar it changes the screen resolution. For the standard monitors, older ones the ratio was 4:3, and new ones are 16:9 or 16:10 (widescreen). So if you've selected a 4:3 resolution it will stretch to 16:9 for example, and you get that stretched look.
What you want to select in that slider bar is one of the following (if you have the option):
1280 by 768
1280 by 800
1366 by 768
1280 by 854
1440 by 900
1440 by 960
1600 by 900
1600 by 1024
1680 by 1050
1920 by 1200
2560 by 1600
3840 by 2400
If none of these are options then you might try updating the video card driver or upgrading your video card to one that can handle widescreen.
Hobb3s is offline   Reply With Quote
Old 04-18-2008, 05:30 PM   #8
Thanks for your help and I did exactly as you stated. But my options are not as high as it should be for the monitor.
But I am use to it now. A little stretched but that's ok. I don't want to put any money into it as I am going to purchase another one.
Old 08-01-2008, 07:34 PM   #9
Ash
Send a message via MSN to Ash
It is quite rare that a computer does not support a resolution
I am working now at a very old computer with 1680x1050 widescreen and it is configured to show correct picture
Try to update drivers of your video card (in Windows) or manually add the resolution to the list (in Linux)
Ash is offline   Reply With Quote
Screen door...Where to get it? eric s General DIY Discussions 6 04-13-2016 08:03 AM
Where to buy TruScene-type screen material? NateHanson General DIY Discussions 18 03-26-2011 10:12 PM
Andersen Screen Repair tennisnut General DIY Discussions 1 12-08-2006 06:10 PM
screen for window aclerok Building & Construction 1 10-28-2006 08:26 PM
