Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 08-25-2010, 12:30 AM   #16
Mr.
Slow computers
That's normal. newer softwares demand higher specs to run on. I suggest upgrading your ram or your motherboard altogether. But I think it'd be cheaper for you to buy a new one.
timothytaylor is offline   Reply With Quote
Old 08-30-2010, 10:37 AM   #17
Custom Home Builder
Slow computers
90% of the time you can speed up your computer by doing a re-format and re-install. My brother does those all the time for people.
ryanjm is offline   Reply With Quote
Old 09-18-2010, 04:42 AM   #18
Slow computers
True, but if you are seeing slowdown in just normal PC usage like Internet Browsing, Editing Documents, etc. then its probably one of 3 things, some already mentioned here:
1) overheating of CPU or video do to dirty PC components, so CPU needs to throttle back
2) malware has infected the PC, number one cause on most of my families PCs that I bring back to life. I always hear when I am done - "Wow, it runs like the day I bought it"
3) Defragmented hard drive and swap file. Can be corrected with defragmenter like Piriform Defraggler.
For malware, I generally suggest most people backup their data (My Documents - Pictures, Music, etc) and system drivers (using Double Driver), and then do a full format and reinstall of Windows, their drivers, and their applications. Its a pain but the best way to cure the root cause and be sure.
Saw one computer so badly infected with malware that it took 2 minutes just for the start menu to display after clicking on it. When I was done with fresh install on Windows, it was running like the day it was bought
If you insist on trying to first clean malware, then these are a must to use:
http://www.superantispyware.com/index.html
http://www.malwarebytes.org/mbam.php
http://www.maximumpc.com/article/how..._pc_junk_files
http://www.downloadsquad.com/2009/10...-antivirus-36/
If you are running your computer without a good Anti-Virus software like NOD32 or Norton and not behind a hardware firewall (aka router) then you are just asking for trouble. British TV show did a experiment on TV with a computer expert and showed a computer with no anti-virus software and directly connected to internet without hardware firewall being hacked and taken over in less then 2 minutes.
Keep your software up to date using:
http://secunia.com/vulnerability_scanning/personal/
matrixman is offline   Reply With Quote
Old 09-18-2010, 09:34 AM   #19
Pro Flooring Installer
rusty baker's Avatar
Slow computers
Norton is terrible.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
BigJim (09-20-2010)
Old 09-20-2010, 03:23 AM   #20
Garage Door Installation
Slow computers
Originally Posted by brandonriffel View Post
Any time I help a friend with their computer, I put Microsoft's free antivirus software on it, Security Essentials.
How good is Microsoft Security Essentials? My NOD32 subscription is expiring and I'm debating whether to renew it or get a different antivirus.
FLGarageDoors is offline   Reply With Quote
Old 09-22-2010, 08:15 PM   #21
Slow computers
It is improving alot. But for me I like to bet on a consistent company for protection - NOD32, Kaspersky, and Norton seem to be in that class. Well, Norton since 2009 and pre-2000
Old 09-22-2010, 08:42 PM   #22
Slow computers
Use Avast. It's free and better than the ones you pay for.
Old 09-22-2010, 09:28 PM   #23
the Musigician
DangerMouse's Avatar
Slow computers
None is perfect, I recommend using different ones.
www.malwarebytes.org is another good one.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 09-23-2010, 09:21 AM   #24
Slow computers
DM
I'll second on malwarebytes . I use it . The first time i ran it it pick up around 200 item's. Once removed tham . All is better. I run it all the time and now it pick's up nothing. I install it on all the comp. that is check out. A good product. And free
del schisler is online now   Reply With Quote
Old 09-23-2010, 09:34 AM   #25
the Musigician
Slow computers
I stayed on the phone with a forum member for over an hour while they ran malwarebytes. It found 311. After they were gone, the machine went back to normal operation. (LONG lag beforehand.)
DM
Old 09-23-2010, 02:04 PM   #26
Slow computers
Originally Posted by rusty baker View Post
Norton is terrible.
Are you basing this on current experience or past? What version are you commenting on?
Did you upgrade to a newer version of Norton or was it installed on a freshly installed version of Windows? Are you sure you are only running one Anti-Virus software?
Prior versions of Norton were a bear to remove and thus installations of newer versions or updates over old versions were very problematic.
Norton sucked big time prior to the 2009 release, but in 2009 they rewrote the software from the ground up and in 2010 improved it even more.
I bet you that their prior versions that sucked were based on dumb management looking to save money and outsource the development. I am a programmer and I see code that outsourced labor has written and its scary stuff. Its no surprise that when the last major botnet infection happened, they said it was easier to mention the fortune 500 companies that were not hacked then the ones that were. Just recently the huge corporate Chase bank online site was down for 2 days, I wonder how that happened
In 2008 and prior, I warned friends and family to stay far away from Norton, but in 2010 I have no issues recommending it. It has a nice overall package suite of security tools.
Personally, I use NOD32 main computer and for my other machines the Free Avira AntiVir.
Also a good idea to look at unbias test results like:
http://www.av-comparatives.org/
http://www.virusbtn.com/news/2010/08_16a.xml
The results for G-Data look pretty impressive and I will need to take a look at them.
Old 10-26-2010, 01:58 PM   #27
jlhaslip's Avatar
Slow computers
The best Malware remedy is running a Linux Operating System.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 10-26-2010, 10:51 PM   #28
Slow computers
Originally Posted by Tizzer View Post
I've had McAfee on this desktop since new. It still runs as fast, but I did double my RAM about about a year ago.
I use the above mentioned Ccleaner and use adblockers on whatever browser I'm using. Pages load faster w/o the ads.
remove the macaffee and go with free microsoft security essentials.
detyianni is offline   Reply With Quote
Old 10-26-2010, 11:07 PM   #29
Slow computers
Or avast. MaCafee has a lot of problems.
Old 10-29-2010, 10:45 AM   #30
Slow computers
I just started using ubuntu on an OLD laptop in the house for browsing and its the fastest computer (even though its the oldest) ive got!
Motor runs slow PillMD Electrical 2 04-06-2010 11:13 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
Slow leak under sink after fixing clog gunzour Plumbing 4 11-30-2009 10:27 PM
Attic Fan Runs Slow kcarrier Electrical 19 07-28-2009 09:57 PM
slow flushing toilet jlandry Plumbing 3 02-02-2009 02:42 PM
