Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 01-31-2008, 09:26 AM   #1
Lightbulb
slow clock
Any idea why my clock would lose about an hour a day???
Dell...approx. 7 years old...running ME, Thanks, Al
econoline is offline   Reply With Quote
Old 01-31-2008, 10:26 PM   #2
Pro Painter
slow clock
The first thing that comes to mind, is that it's time to change the battery.
The second is that your time zone settings aren't being retained.
The third thing is, well.....it's ME.
joewho is offline   Reply With Quote
Old 02-01-2008, 01:53 AM   #3
slow clock
is it a DIY job...like a watch battery???
Old 02-01-2008, 02:51 AM   #4
wfischer's Avatar
slow clock
very easy to do... takes maybe 5 min.
wfischer is offline   Reply With Quote
Old 02-01-2008, 06:54 AM   #5
poppameth
Guest
Posts: n/a
slow clock
Most PCs use a CR2032 Lithium battery. They are coin cells like a big watch battery. I usually order the Newsun brand off of Amazon. I can get a 5 pack cheaper than I can buy one locally. Main thing to remember, is to enter your BIOS and write down all the setting if possible before replacing the battery. Many motherboards won't retain the BIOS settings when the battery is removed and you'll have to reset them manually.
Old 02-01-2008, 11:32 AM   #6
Pro Painter
slow clock
This is a DIY job, if you take your time. Go to the Dell site and look up the model number of your computer. If your Dell support isn't current, don't worry, you'll still be able to download the info you need.
You can open the computer case and look for the battery physically. It's the disk shaped kind. It's mounted in a round plastic holder. Don't pry it out, there's always some protruding piece to push on and it will pop out, like toast.
After installing the new battery, you have to go to the bios and reset the time and date. Again, check the dell site to see how you navigate that. You'll be using the arrow keys, enter key and escape key. Very easy once you see how to do it. Good luck.
Old 02-01-2008, 01:35 PM   #7
slow clock
Provided the battery wasn't just soldered to the mobo.
perpetual98 is offline   Reply With Quote
Old 02-01-2008, 04:23 PM   #8
Thumbs up
slow clock
Thanks to all...lots of good help...just added this to my to do list for this weekend...will let you all know the outcome. Al
Old 02-01-2008, 06:23 PM   #9
slow clock
before you bother - you can download this free program (which does not have any spyware or viruses) and it will adjust your computer clock daily for windows prior to xp (xp doesn't need it cause you can set it to check a timeserver automatically)
http://www.altrixsoft.com/en/chrono/atomic-clock.php
nacko is offline   Reply With Quote
Old 02-04-2008, 12:10 PM   #10
slow clock
Change the baterry, it is a round small one, the cost don't have to pass the 3 dollars, well it deppends where you buy it
LuisaAndrews is offline   Reply With Quote
slow....................internet RichyL PC Repairs & Upgrades 16 10-20-2009 08:57 AM
Yup, the site is slow Nathan General Discussion 6 01-21-2008 10:32 PM
stool flushes to slow dtarbet Plumbing 3 12-28-2007 07:46 PM
Wood Clock wackydesigner Carpentry 8 09-11-2007 09:44 PM
tub drains slow new construction clibertyusa Plumbing 5 04-04-2007 01:51 PM
