Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 04-11-2011, 05:22 PM   #1
Safe Mode??
What is the purpose of running an anti virus or malwarebytes in safe mode?
Giles is offline   Reply With Quote
Old 04-11-2011, 06:55 PM   #2
"Nail-Bender"
Safe Mode??
Giles -
Some "Malware" does not run in "Safe Mode" - it's been written to run
when the operating system starts in "Normal" mode.
(Unfortunately, some of that "stuff" runs whenever it wants).
Is there some reason you're concerned about running in "Safe Mode"?
rossfingal
rossfingal is offline   Reply With Quote
Old 04-11-2011, 07:02 PM   #3
the Musigician
DangerMouse's Avatar
Safe Mode??
A lot of the malware is written to hide when windows loads completely so it cannot be seen with a normal scan.
Safe mode scans can find some that hide this way.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-11-2011, 07:02 PM   #4
Safe Mode??
Originally Posted by rossfingal View Post
Giles -
rossfingal
No--I have read, on different forums, about running in safe mode and I just wondered if it worked better.
Old 04-11-2011, 07:41 PM   #5
"Nail-Bender"
Safe Mode??
Try to run anti-malware (anti-virus, trojan, etc...) tools in "Normal Mode" -
the next attempt would probably, be "Safe Mode" -
the next attempt would be "specialized" tools, run with the
guidance of someone trained to utilize them.
rossfingal
Old 04-12-2011, 11:39 AM   #6
Safe Mode??
Giles,
Most advanced malware and viruses will disable antivirus or malware removing tools in "normal mode" or will make a computer unusable.
Starting in "Safe Mode" loads only essential Windows files and processes and nothing else (not even antivirus). The idea is that nothing is loaded unless you tell it to, so a virus or piece of malware won't load and you can manually run an antivirus scan to remove it. This isn't always the case, but it's an effective way of removing a virus or malware that can't be removed in normal mode.
Synon is offline   Reply With Quote
The Following User Says Thank You to Synon For This Useful Post:
Giles (04-12-2011)
Old 04-15-2011, 03:04 PM   #7
Tizzer's Avatar
Safe Mode??
I'm no geek, but around a month ago my AV found a "baddie" during a routine normal mode scan. It said it couldn't get rid of it, but gave the file location.
Malwarebytes missed it in normal mode also.
Booted into Safe mode under Admin. and manually plucked the bad file.
Tizzer is offline   Reply With Quote
The Following User Says Thank You to Tizzer For This Useful Post:
Giles (04-15-2011)
Old 04-16-2011, 12:34 PM   #8
Safe Mode??
Originally Posted by Synon View Post
Giles,
This is the reason. When malware loads, it tries to be smart and hides/reinstalls itself, disables anti-virus, prevents the antivirus from deleting it, etc. In safe mode, you can delete it and it shouldn't be able to reinstall itself.
whiskers is offline   Reply With Quote
Maytag Dishwasher stuck on rinse-only mode - mdbtt60awq WaldenL Appliances 2 06-22-2010 11:46 PM
motion, photosensor, light switch to choose mode joshoc Electrical 5 12-18-2009 01:49 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
