Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 12-20-2007, 12:12 AM   #1
Smile
reload windows
Hello ,I bought a old pc which has a copy of xp but no license for the os so I need to format the system and reload windows, anybody know step by step instruction if so please post as soon as possible
jackkittino is offline   Reply With Quote
Old 12-20-2007, 06:43 AM   #2
NothingsLevel's Avatar
reload windows
Buy a license for it. Even before you had to wipe the system, the seller should have transferred the license to you if he didn't wipe XP off it himself.
NothingsLevel is offline   Reply With Quote
Old 12-20-2007, 11:42 AM   #3
Remodeler
MinConst's Avatar
reload windows
I can help, ut lets find out some things first.
Does this computer have a recovery partition? What brand is it?
I take it the is no COA (License) on the side ot bottom from Microsoft?
Do you have a copy of XP to replace this with?
Does the machine boot into windows now so you could make a boot disk?
Answer these ?? and I will continue/
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 12-24-2007, 04:06 PM   #4
reload windows
answer to all is none of that no to all above
Old 12-24-2007, 04:17 PM   #5
Remodeler
MinConst's Avatar
reload windows
So if you have a legal copy of XP then put the CD in the drive and boot from it. You may need to change the boot sequence in BIOS to allow booting from the CD. Run through the XP setup from the CD and choose to delete the partition. Then just follow through with the setup. You may need to find some drivers for hardware in your machine if they are not all included with XP. If you right click on my computer and choose properties and look at device manager and see any ! marks. Search for the drivers needed on the Internet. Obviously you will need either a LAN driver or modem driver depending on how you get access. Good luck.
Old 12-25-2007, 04:59 PM   #6
reload windows
Having been down this path many times [I run a small office computer network business] let me offer some tips:
1: when you say, 'no license', you know this for a fact? Many computers I see are fully licensed but there is no outward appearances. If you want to be sure, go to microsoft.com and try to download the latest security patch. If you have an illegal copy, the site will tell you. And no, don't worry about black helicopters overhead. MS will not come to your door. I have checked dozens of computers this way, just to be certain they are legal. [operating my own little company, I am NOT going to work with illegal softare]
2: do NOT format the drive! There is no reason for this, unless there are other compelling reasons. But formatting is like jumping off the cliff--no turning back. You can always format later as a last resort if things don't work out.
3: if necessary, buy a legit copy of XP on a CD. I prefer the XP Pro, but that's me.
4: boot up and place the CD in the drive bay. it should pop up an run. Have the ID numbers handy.
5: Important: when the installation "sees" another copy of XP on the drive, it will ask if you want a new installation or copy over the old one. Be CERTAIN to install over the old one, otherwise you will have two completely different versions of XP and it will drive you and the computer nuts!
6: the new will totally replace the old, so not to worry.
Holler if you have more Qs.
bob
robertpri is offline   Reply With Quote
Old 12-29-2007, 04:06 PM   #7
Smile
reload windows
When I purchase the pc at the flea market, dirt cheap they inform me that there was no software available,also they inform me that the os was xp but don't know if the os was a legel copy or blackmarket copy. I try to update system but a pop up box appear copy is not legel please purchase, the computer is fairly new had to purchase a monitor so now I am trying to format system and load window 98 second edition which I have a legel copy . Will not invest money into system which an new xp os goes for 100.00 . is there any software which I can use to delete file and formay hard drive . thanks jack
Old 12-29-2007, 05:01 PM   #8
reload windows
If they didn't give you install media and the license, then you're probably outside the licensing agreement.
If the guy selling you the system doesn't know if the OS is properly licensed, it almost definitely is not.
Well, if you consider that you puchased the system for $100 under the "true" value because it has an unlicensed OS on it, look at it as buying the rest of the system.
If the hardware is new enough Win98 won't run on it. Are you sure that you have a "legal copy" or is it a CD you used on another PC?
If you buy a legit copy of XP, you can format the drive right in the installer.
Win9x, being based on DOS, has all the tools you need to make a boot floppy containing fdisk and format, plus the CD drivers to be able to access the Win98 setup on the disc.
Or you could download any of the various Linux distributions for free & install that.
Old 12-29-2007, 05:47 PM   #9
I have gas!
Clutchcargo's Avatar
reload windows
You should be able to drop in the Win 98 disk and it will walk you through partitioning and formatting the hard drive and finally and installing Windows.
GL
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 12-30-2007, 11:46 AM   #10
reload windows
If it doesn't have an OS and you don't want to buy one, the only option I can see is (assuming you intend to be legal) to load Linux. Ubuntu has a couple of different flavors. If you don't have a way to download and burn to a CD, they have an option where they will ship a couple of CDs for for free: https://shipit.ubuntu.com/ . Good luck.
newski is offline   Reply With Quote
Old 12-31-2007, 11:45 AM   #11
reload windows
There is a little program to get your keys , can not remember the name right now. Will find on some of my backup disk and post it if is alright. It is legal and hope is not a boot leg copy. And also you can find it on the net.
ajh359 is offline   Reply With Quote
Old 12-31-2007, 11:56 AM   #12
reload windows
That won't change the fact that MS is of the belief that the license key he's using isn't legal.
Old 01-02-2008, 10:23 PM   #13
Fire Fighter-
Klint's Avatar
reload windows
You can view your current CD Key with this > http://www.nirsoft.net/utils/produkey.zip
To reinstall Windows you will need an XP cd, more than likley (if it's "blackmarket" you wil need an XP PRO ENTERPRISE CD. LEt me know if this helps and if you have any other questions
Thanks,
Klint T.
Klint is offline   Reply With Quote
terrible windows mt232 General Discussion 10 12-28-2008 06:37 AM
How to caulk windows the RIGHT WAY? fritzycat1 Painting 3 09-10-2007 07:32 PM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 11:23 AM
new windows juliejules4 HVAC 12 12-06-2006 02:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
