Hi! This is Zach with Expert Village and today we are going to talk about USB hard drives and USB external storage. USB is a standard that is found on most modern computers if not all. These are examples of USB connectors. Generally this is the end that... Read More »
Hi! This is Zak with Expert Village, and today I’m going to talk to you about plugging in your USB printer. Most printers today come with USB cables and ports to appose to older printers, which used parallel ports, and serial transfer, USB is much... Read More »
This is Zach with Expert Village and today I am going to talk to you about using multiple external storage devices on the same computer. Here you can see we've got two drives. The bottom is already connected with the USB connection in back of the... Read More »
The serial port used to be a standard connector for mouse, keyboards and miscellaneous computer hardware such as digital cameras and personal data assistants. Faster USB ports have mostly replaced serial connectors, but serial ports are sometimes used... Read More »
Hi, my name is Tony Ramirez from Tampa, Florida. On behalf of Expert Village, this is audio for your PC. In this jungle of cables that we have here, is the back of the computer with the USB. So the first thing I'm going to talk about is the USB audio... Read More »
