Problem With USB Optical Mouse - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 11-22-2010, 05:51 AM   #1
Rewards Points: 304
Problem with USB Optical Mouse
I have a wired USB optical mouse and seemingly every second time I turn the PC on, the mouse will not work. Without turning off the PC I simply remove the plug from the USB port and put it back. Whoooohooo..."found new USB device". Then it works fine until the next or the next time I boot up.
I have 6 USB ports and no matter which one I try, it will eventually give me the same problem. This does not happen with any of my other USB devices, just the mouse. Any suggestions or is it time for a new mouse.? Thanks.
polarzak is offline   Reply With Quote
Old 11-22-2010, 05:54 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
It's probably a quirk between the mouse and motherboard. My girlfriend has a Razor Diamondback and so do I. Her old computer would intermittently do the exact same thing. Mine has never had a problem. Since I rebuilt her PC she has had no issues with the mouse.
poppameth is offline   Reply With Quote
Old 11-22-2010, 12:39 PM   #3
Rewards Points: 304
Thanks for the reply. I am going to change the mouse and see it that helps. The MB is relatively new so I am not planning to replace it soon.
EDIT. NOV. 24.....for future readers, it seems the problem was the mouse.
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
