Printer Problems - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Like Tree1Likes
  • 1 Post By ZZZZZ
Old 04-15-2017, 06:21 PM   #1
Rewards Points: 216
Printer problems
My kodak esp office 2150 wont turn on. It does nothing, no powet light or anything. Any ideas ? Thanks.
shirbon is offline   Reply With Quote
Old 04-15-2017, 06:25 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
Re: Printer problems
Try another outlet and check the plug where it goes into the printer.
If it isn't either of those, it won't be worth fixing.
Old 04-15-2017, 06:29 PM   #3
ZZZZZ's Avatar
Rewards Points: 2,760
Some older printers had replaceable fuses. Check your owner's manual.
Windows on Wash likes this.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 04-15-2017, 06:47 PM   #4
+1
Here is the manual. Can't find any reference to fuse in it.
http://resources.kodak.com/support/p...xUG_GLB_en.pdf
Old 04-15-2017, 08:05 PM   #5
Rewards Points: 216
Its not the outlet as the green light on power pack on the cord lights up. I've unpluged it from the wall and unpluged it from printer with no results either. Havent tried to look for a fuse yet though. The manual pretty many ch just says make sure its pluged of in, not much other help.
Old 04-15-2017, 08:16 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 1,986
It looks like the printer has a low voltage DC input. The pilot light might just detect AC power. If you have a meter you could check the output of the power supply unit (or have a similar spare power cord in a drawer like many technology owners).
lenaitch is offline   Reply With Quote
Old 04-16-2017, 08:18 AM   #7
Rewards Points: 216
I could test the power but what is it supposed to be at ? At the printer entry point is it still AC or maybe been converted to DC ?
Old 04-16-2017, 08:30 AM   #8
Rewards Points: 46
DC. It'll say the voltage on the power brick. It may also say on the printer too. Printers are typically 12-18Vdc.
Cheers!
supers05 is offline   Reply With Quote
Old 04-16-2017, 09:30 AM   #9
joed's Avatar
Rewards Points: 13,346
It appears to be 36 volts.
Available from amazon.
https://www.amazon.com/T-Power-Adapt.../dp/B00GU7N0IG
Old 04-22-2017, 08:35 AM   #10
Rewards Points: 216
Its putting out about 35.6 volts
Old 04-22-2017, 08:37 AM   #11
Rewards Points: 216
It just wont turn on. I suppose its junk, thats the way these electronic gizmos work.
Mac Problems l008com PC Repairs & Upgrades 4 06-25-2016 09:17 AM
Printer Problems ModelAFan PC Repairs & Upgrades 10 05-28-2013 08:24 AM
Hot water problems - not sure what's causing it ngk Plumbing 6 03-29-2013 06:42 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
