PC Will Not Boot - PC Repairs & Upgrades - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 09-04-2012, 01:10 PM   #16
You said that you have substituted all the parts, but did you check that the power supply is producing both 5 and 12 volts.
If its only putting out 5 volts, the fans and lights will come on but without 12 volts it won't boot!
Recently my desktop wouldn't boot and it was the power supply! Cost me $20 for a new one!
Old 09-04-2012, 04:46 PM   #17
bbo
ive already put two pc's side by side and pirated on the "good" pc power supply to verify the PS was bad before purchasing a new one.
bbo is offline   Reply With Quote
Old 09-04-2012, 05:32 PM   #18
Rewards Points: 304
Tried a known good spare power supply. Same result. Nothing only fans.
Good call though.
polarzak is offline   Reply With Quote
The Following User Says Thank You to polarzak For This Useful Post:
bbo (09-04-2012)
Old 09-05-2012, 07:09 AM   #19
Rewards Points: 252
Originally Posted by rugburn View Post
I'm going to side with most everyone and guess your MB is toast, but double-check that everything is seated properly and no dust / debris is present in any of the slots. I work on PC's quite frequently at work and am guilty of this more often than I'd like to admit.
Agreed. I had suggested bad capacitors as a possible cause as this is such a common problem and displays the issues he is seeing. I also do a lot of work on PC's both individual and businesses.
OP, I would suggest looking at this site as well...
www.badcaps.net
But, you can pick up a new MB or used one pretty cheaply instead.
Marty1Mc is offline   Reply With Quote
Old 09-05-2012, 09:02 AM   #20
Rewards Points: 304
www.badcaps.net
Thanks for the site. Interesting, so I looked at my capacitors, and none display any of the signs of a dead one, (not to say one isn't dead) so I will wait until my new BIOS arrives. If it doesn't do the trick, I will go with "door number two" and pick up a used MB cheap. Thanks everyone for your help and suggestions.
Old 09-24-2012, 09:04 AM   #21
Rewards Points: 304
I received the new BIOS chip and still no luck. I have concluded, as most of you have , the MB is toast.
Thanks for everyone's input.
Old 09-24-2012, 09:20 AM   #22
the Musigician
DangerMouse's Avatar
I had a similar situation, and I got an entire machine in good working order from craigslist for $50.00.
I'm using that machine still.
DM
Old 09-28-2012, 08:45 PM   #23
Missouri Bound's Avatar
Newegg is also a good choice for MB's...my favoirte PC source.
Do you want it your way or the right way?
Vent Pipe Boot handy man88 Roofing/Siding 19 05-14-2012 01:18 AM
Making End Boot Smaller unixb0y HVAC 1 09-21-2010 06:30 PM
cost to replace return boot and filter box..... BlueBSH HVAC 5 08-06-2010 08:50 AM
Attaching Flex duct to register boot avshockey HVAC 15 12-03-2008 08:07 PM
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 05:26 AM
