PC Completly Dead - Please Help!!! - PC Repairs & Upgrades - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 05-31-2008, 01:18 PM   #16
Originally Posted by lostintrans View Post
Hi - hoping someone can help me out here - my PC a dell just over i year old, is just non responsive! i mean not a kick out of it!
now i already did a little troubleshooting of my own
- swapped out the power supply and it is worling fine
- also swapped out the hard disk and it is working fine
- there also seems to be power going to the mother board because that little green LED is lighting on the motherboard. but the pc just wont power up!?!
so just what else could prevent the computer from even trying to start up!!
now it has not had any knocks or anything like that so any help anyone can give me, i would be most greatful!!!
thomas.
I have had a similar experience which I have solved after many hours by simply cleaning the area between the motherboard and the PC casing. You would be surprised to see how must dust and "woolies" accumulate in this section, it being out of sight. Good Luck!
Bok Roodt is offline   Reply With Quote
Old 06-04-2008, 07:18 PM   #17
Smile
What model Dell is this
I work on them all the time. the GX 270s had a problem with bad capacitors. Look for a buldge or look for a rust corrosion on top of them. The symptops can be the following
1. that the PC turns on, but no video from the monitor.
2. Thermal overheating error
There may be more symptoms, but those were the only ones I got.
Topdog is offline   Reply With Quote
Old 08-01-2008, 06:15 PM   #18
Ash
Send a message via MSN to Ash
Remove the CMOS battery and connect a LED to it. if it does not light up bright then the battery is bad
Remove everything (all cards + memory + cpu) and disconnect all drives. Try to just power on the board. Keep the buzzer and the power button connected
Try to power up
Disconnect mains
Insert cpu and its cooling device
Connect mains
Try to power up
Disconnect mains
Insert one memory stick
Connect mains
Try to power up
Try to exchange the memory sticks (with the mains power unplugged) until computer shows signs of life
Beeps from buzzer usually mean try another memry combination
Ash is offline   Reply With Quote
Old 09-07-2008, 05:14 PM   #19
It is surely a RAM or Memory fault. I think you should try replacing it or if you have 2-3 different RAMs then you should try with 1 RAM only.
Last edited by AtlanticWBConst.; 09-08-2008 at 08:06 AM. Reason: Site Rules Violation: Advertising Link Removed from Signature
wilsonmian is offline   Reply With Quote
Old 09-07-2008, 09:57 PM   #20
Is it out of warranty? Go to Dell's site and punch in the service tag on the warranty info page.
Did you get a lightning storm recently? I've seen many Dell Motherboards get fried by lightning. The boards I've replaced that were not under warranty were about $80 from Dell.
I always buy one of their 3 year warranties with every system now.
If it does nothing when you press the power, you probably have a dead motherboard.
KHouse75 is offline   Reply With Quote
Old 10-05-2008, 01:38 AM   #21
Rewards Points: 1,016
Power supply bad - or power supply and the motherboard are both bad (power supply goes bad and takes out the motherboard).
Old 05-05-2009, 01:54 PM   #22
Originally Posted by Vandy View Post
I would prefer you to contact Dell for the fault and try to get it repaired.They will be the best to help you out even if they will cost.Your monitor might have some problem or get your ram might be dislocated.Just try to refix each part of your laptop.Otherwise visit dell service center.
I'm not sure why people pull up a thread 1.5 years old
The original poster has NEVER replied to this thread
In fact he hasn't been back to this sit in almost a year
Old 05-08-2009, 11:21 AM   #23
Yeah
I think it was bad mobo caps just incase anybody wants to know.
rgsgww is offline   Reply With Quote
Old 07-24-2009, 12:18 PM   #24
Well maybe others can still get something useful out of it instead of creating a new version of the same thread, even if the original poster is MIA, but who knows.
As an aside, and referring to the original problem and replies...
One thing almost always overlooked is the power button on the case. I just handled this for a friend whose PC 'just died'. The power button broke. Sometimes it *is* something simple
CodeJock is offline   Reply With Quote
Dead outlet and switches on otherwise live circuit viking1974 Electrical 4 08-23-2007 05:30 PM
Dead Battery larock5 Tools 2 06-20-2007 10:00 PM
Lenox G8 series blower dead...almost MSP HVAC 1 02-18-2007 12:15 AM
dead transformer otis_ofnh Electrical 3 02-11-2007 12:19 AM
