No Connection - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 09-10-2011, 12:10 AM   #1
Unhappy
no connection
Mom's computer crashed so i reinstalled xp. Went on net. to get updates. The first update was service pack 2, and the computer could still surf the net.The next update was service pack 3 once the computer restarted I tried to get on net. and it say's page can not be found. The computer is a dell dimension 2400 that uses a wireless usb netopia.
bignezzy74 is offline   Reply With Quote
Old 09-11-2011, 11:31 AM   #2
Busy DIYer
picflight's Avatar
Rewards Points: 150
Check the network settings. Updates will not change your settings.
picflight is offline   Reply With Quote
Old 09-18-2011, 11:59 AM   #3
Rewards Points: 6,652
Most likely incorrect driver for the usb wifi device.
Old 09-28-2011, 10:37 PM   #4
If you make a fresh install and then go on the net without a good antivirus and firewall, you will likely pick up a virus before you are connected to download the updates.
I speak from experience.
I follow this routine! I download a good antivirus program and save it to a CD. Then,I format the hard drive with the Windows Installation CD. And install Windows.
When Windows is installed, I install the antivirus program from the CD,next.
Then, make sure that the firewall is turned on.
Now you can safely connect your computer to the internet and down-load the updates.
I formatted my h/d three times before I learned this lesson.
Low Hot water pressure after replacing laundry hose connection jp_jacobson Plumbing 4 05-03-2011 08:30 AM
3 way switch with pass through power connection issue ccmbee Electrical 2 09-28-2010 03:38 PM
Water softener connection question Aldyrin Plumbing 1 09-22-2010 10:30 PM
gas dryer connection question rvegab00 Plumbing 7 12-07-2009 11:53 AM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 07:10 AM
