New DVD Burner - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 08-04-2010, 08:43 PM   #1
Fixer upper guy
Rewards Points: 12
New DVD burner
So I am installing a new DVD burner. I have an old DVD player installed that uses an IDE ribbon cable. The new DVD burner is SATA. My mother board is capable of supporting IDE drives as well as SATA drives. My question is will I have any conflicts if I am running 1 IDE DVD player, and 1 SATA DVD burner?
In theory both will work correct?
teg916 is offline   Reply With Quote
Old 08-04-2010, 08:56 PM   #2
the Musigician
DangerMouse's Avatar
I don't see any problems, it's made to use either/or. Po) (separate slots, right?)
If it blows up, blame the next guy to post for being too slow to correct me. LOL
DM
Old 08-05-2010, 06:53 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
You may have problems. It depends on how the SATA chipset and the BIOS of the the mobo handle the connection. I have an old Dell Dimension 8300 with both types of connections but if you want to use SATA then your boot drive has to be on one of the SATA controllers. Trying to attach anything else with your boot drive still on an IDE controller causes all kinds of problems. What is you computer make/model?
poppameth is offline   Reply With Quote
Old 08-05-2010, 07:02 AM   #4
the Musigician
Good point, I was assuming the HDD was on SATA. If so, there SHOULDN'T be problems.... but... you never know.
DM
Old 08-05-2010, 11:17 AM   #5
Fixer upper guy
Rewards Points: 12
It's a homebuilt computer. The motherboard is an Abit KN9. The hard drive is SATA.
Old 08-05-2010, 11:51 AM   #6
the Musigician
Abit's a good board, and since the HDD is SATA, I don't think you'll have any problems (on different sockets)
DM
monitor heater repair help speakers3 HVAC 16 01-18-2015 05:00 AM
furnace burner problem brent h HVAC 2 01-11-2010 08:50 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 10:05 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 02:37 PM
