my laptop battery cause I need it in case my power cuts out
The battery only charges while on power, and when it is needed. In other words, if you unhook from A/C, then plug back in, the battery will be charged, and not charged any further.
Most batteries will only last 2 maybe 3 hours, unless you have a SSD drive installed, then you may get around 6. I can get 18 hours out of my netbook with the SSD drive in it. If I need to charge it, I can take it out to our van and plug into the a/c plug in it.
Also with power outages, goes no Internet.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
