Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 12-15-2012, 10:55 AM   #1
my clock keeps changing
windows 7 ultimate. the clock is wrong every time i boot up. wth is up with that ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 12-15-2012, 04:55 PM   #2
"Nail-Bender"
Replace the battery on the mother-board.
"RF"
rossfingal is online now   Reply With Quote
Old 12-16-2012, 12:18 PM   #3
"RF"
your close to me, can you come do it
if i decide to just leave it ( i have a clock on the TV), will it cause any other issues ?
Old 12-17-2012, 08:28 AM   #4
"Nail-Bender"
No, it "probably", will not be an immediate problem.
It can indicate, the battery is losing it's ability to hold a charge.
If the problem is the battery - there may come a time -
the computer will not "boot".
rossfingal
Happy Holidays!
Old 12-17-2012, 09:20 PM   #5
thanx. oddly enough, the clock has been keeping time that last few boots. hmmmm
Old 12-19-2012, 05:21 AM   #6
"Nail-Bender"
That's good!
However, a computer, battery that's losing it's ability to hold a charge -
quite often can be intermittent.
"RF"
The Following User Says Thank You to rossfingal For This Useful Post:
Fix'n it (12-19-2012)
Old 12-19-2012, 09:14 PM   #7
Are you multi-booting with another operating system.?
Just thought I would mention this since I ran into an issue a while back where linux (ubuntu) was changing the system clock whenever I booted into it, so when I booted back into windows it was wrong (I think by 1 hour). That one was tricky to figure out. Had to change something in ubuntu to fix it (I don't recall the specific setting, but it wasn't too hard to find once I new what was happening).
Otherwise, the mobo battery could be the cause, though I was under the impression that modern mobos didn't completely power down even when shut down.
wrongdave is offline   Reply With Quote
The Following User Says Thank You to wrongdave For This Useful Post:
Old 12-19-2012, 10:25 PM   #8
no multi boot. and it is still keeping time.
Old 12-20-2012, 08:11 AM   #9
"Nail-Bender"
Modern "mobos" don't completely "shut down" -
they have a battery.
The battery keeps the "BIOS/CMOS" info intact - so the computer can "Boot" - without the need for some type of boot disc.
(that's a "rough" explanation)
Yeah - I've got Multi-boot computers -
seen the same thing with the clock.
It can change.
"RF"
Something else to consider -
If you do open up the computer case - to change or touch anything -
Unplug the computer - hold the "power-on" button down for 30 seconds -
Ground yourself to the case on the power-supply
(Or use a "anti-static" strap!)
Static electricity, can destroy sensitive computer components!!
Old 02-24-2013, 10:30 AM   #10
How wrong is the clock? Is it always off by the same amount? Off by exactly n hours? Or is it just random minutes?
If you don't cut power to your computer completely (yank it out of the wall), then the motherboard battery doesn't matter - it's only there for the moments when the machine fully loses power.
Click on the time in the lower right corner of the screen, you should see a calendar pop up. Choose "change time and date settings". Is your time zone correct? Now click on the"Internet Time" tab - is your machine set to synchronize with time.windows.com?
If those are correct, then there's another reason, obviously. COULD be some malware changing your clock, but not very likely.
whiskers is offline   Reply With Quote
Changing Window Size TinaV Remodeling 3 11-06-2012 01:30 PM
GE/Hotpoint clock assembly timer shaft removal Spydey Appliances 0 03-04-2012 12:52 AM
Changing Roof Type Iconoclast Building & Construction 13 07-29-2011 12:15 PM
Cheap suggestions for changing look of bathroom sink countertop? mrdazzo7 General Discussion 11 01-07-2011 06:43 PM
Clock segment burnt out n0c7 Appliances 2 11-06-2008 08:30 PM
