Monitor Out? Repairable ? - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 10-28-2008, 09:35 AM   #1
Rewards Points: 150
Monitor out? Repairable ?
HP flat screen Pavilion f 1503
I turned it off at night and the next day it was black.
My monitor is out, I borrowed my neighbors extra monitor to eliminate the computer. Everything now works. My question is Can a monitor be repaired?
Can it be something simple ? like a bulb ? I noticed a dim HP on the screen once, like the juice was weak or a weak bulb?
I can't afford a new one at this time .
How about buying a used monitor, We have a computer show coming up this next month. I have been there before and saw lots of equipment for sale not real cheep but affordable.
Thanks Deck Hand
deck hand is offline   Reply With Quote
Old 10-28-2008, 03:17 PM   #2
47_47's Avatar
Rewards Points: 62
My friend has had similar problems with a few ACER monitors. Turned out to be bad solder joints.
47_47 is offline   Reply With Quote
Old 10-28-2008, 09:01 PM   #3
Send a message via AIM to nayslayer
I have a few thoughts
Double check the power connections
Does the monitor power light light up? What color?
Boot up pc and take flashlight to screen, do you see your desktop? If this is the case, it's the backlight. Its usually a small cfl bulb and have been successfull swapping them out on laptops, and i have been unsuccessful. I got them on ebay, they are model specific.
nayslayer is offline   Reply With Quote
Old 10-28-2008, 09:05 PM   #4
Well i did a little digging and found this thread, may be worth the shot, just need a soldering iron and some time
http://forums.cnet.com/5208-7590_102...sageID=2677421
Old 11-08-2008, 04:37 PM   #5
Many tech items are no longer cost effective or able to be repaired by local techs. Monitors are relatively cheap so it might be best to get a new on rather than attempting to fix the monitor yourself. If you connect the wrong line to a wrong power source you could fry components on your main computer. be very careful if you decide to go that route.
Last edited by AtlanticWBConst.; 11-09-2008 at 09:17 AM. Reason: SITE RULES VIOLATION: Advertising Links Removed from Signature
AustinREDevelop is offline   Reply With Quote
Old 11-09-2008, 09:08 AM   #6
crawdoogie's Avatar
If you haven't be sure to check out leslie wong's blog:
http://www.lesliewong.us/blog/2005/0...kout-solution/
as it mentions some other possible fixes (i.e. bad caps) and has pics
(the link was in the cnet forum in your post)
other tips:
-use 60/40 tin/lead solder
-use hand lens to inspect as cracks in solder joints can be hard to see
-in addition to the torroids, the power connector jack is known for failed solder joints
If you need to desolder any components Radio Shack sells an inexpensive desoldering tool for about $11. Usually RadioShack blows but this is the one item that works well for a very reasonable price.
http://www.radioshack.com/product/in...31&tab=summary
crawdoogie is offline   Reply With Quote
Old 12-03-2008, 09:53 AM   #7
Rewards Points: 150
other tips:
I have deep six this monitor and purchased a new 19"
Thanks deck hand
Damaged backer board during shower tiler removal, repairable? Bobster Building & Construction 2 10-06-2008 10:00 AM
2cm round chip in bathtub - repairable? curls00 Plumbing 2 08-26-2007 12:57 AM
Which Low Slope Materials are Homeowner repairable? Basic_Homeowner Roofing/Siding 4 06-10-2007 09:26 PM
