11-11-2012, 10:23 PM
#31
STAFF
Malwarebytes
Originally Posted by funfool
"My system is XP pro, sp2 and all updates are current. I have Ccleaner and do run it quite often."
That should be sp3 if you are updated.
I've heard too many bad things about SP3.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
11-11-2012, 10:26 PM
#32
Malwarebytes
But you have to have it. Without it you can no longer get Windows updates online.  (or does that only apply to the home version)?
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
11-11-2012, 10:57 PM
#33
DIY Enthusiast
Malwarebytes
You do realize that all that Spam e mail on yahoo is on yahoo's server NOT your pc? Wanna stop the Spam change your yahoo e mail.
The Following User Says Thank You to sublime2 For This Useful Post:
11-11-2012, 11:03 PM
#34
Malwarebytes
I cant imagine what you hear about sp3, but you are really outdated if using sp2.
I installed my wifes system about 4 years ago and has xp pro sp3. Runs fine today.
Only possible thing I can think of, It will take more hard drive space, and will use more ram to run smoothly.
If you have at least 1 gig of ram it should run fine, lower amount of ram and it will still work but will be slow.
Honestly, you are missing out on many many improved updates running sp2 and see no reason not to go to sp3.
I forget the cut off date, but all xp will stop receiving updates.
Quick google search should find it ... they had one date and to many complained and they moved the date again.
If it was easy, we would not call it work!
11-11-2012, 11:12 PM
#35
STAFF
Malwarebytes
This may well be one of my problems, I only have 512megs of RAM and really no way to add more, I don't think this ole motherboard will handle it. I did a defrag, deleted a lot of my files on desktop and did another clean up and the PC seems to be doing good so far, I may be wrong about not having SP3, I will check and see. I don't remember what was said about SP3 being bad but I didn't update it, I don't think.
Jim
11-11-2012, 11:33 PM
#36
Malwarebytes
Check what you have, then go to Microsoft windows update website and see what you are supposed to have.....I'll be if you don't have SP3 then you can't get updates. Post the results, please.
11-11-2012, 11:45 PM
#37
Malwarebytes
Would be curious of what model number or brand your pc is.
sp3 on 512 would suck and be slow. I had old p-3 pc that would accept more then 512.
Is very common to see low end machines off the shelf that have very little ram installed to save on cost.
But they will take and use much more then provided when bought new.
And at one time, 512 was fine for xp, but as apps and updates get bigger, more features added .... 512 is just not what it used to be.
11-12-2012, 01:09 AM
#38
STAFF
Malwarebytes
There is no telling what brand this PC is, a friend of mine up in Alaska made it and sent it to me and he died a couple of years ago. He knew PCs really well and told me I didn't have to up date windows, but everything else needed to be, so I have never updated windows the first time. He told me as far behind updates it was then it would bog down the PC. He told me updating had nothing to do with security.
Right now the PC is doing good again, several members said they were having problems earlier but is good now also.
Jim
11-12-2012, 07:47 AM
#39
"Nail-Bender"
Malwarebytes
It's "Windows"!!!
Install all the updates/patches!!!
As far as I know - SP 3 is fine!
(After they got the usual "bugs" - taken care of!!)
It's "Windows"!!!
Ha, ha, ha!
"RF"
The Following User Says Thank You to rossfingal For This Useful Post:
11-12-2012, 09:54 AM
#40
Malwarebytes
There are a few free programs that would help you find out.
I would boot a live linux cd and from terminal, lspci will give a complete list of hardware.
From windows, Belarc Advisor will give you this info also.
http://www.belarc.com/free_download.html
With this info, you could go to crucial
http://www.crucial.com/support/howmuch.aspx
They have a scan tool that will tell you how much ram you have and what kind your board uses, how much the board will take.
If your pc is running fine now, I would leave it at sp2. Simply 512 is not enough for sp3.
It will run, but sp3 will be more resource heavy, will slow your computer down.
There are many security updates that come with sp3. or simply having sp3 will allow you to receive the updates.
If you use ie for your browser, is major security flaw and will be updated. Also will have mse avaible. sp3 is suggested, but if only 512 I would leave as is.
The Following User Says Thank You to funfool For This Useful Post:
11-12-2012, 12:24 PM
#41
STAFF
Malwarebytes
Thanks for the help guys, I appreciate it but in the mean time, without realizing it I have hijacked kwikfishron's thread, Ron I profusely apologize.
Jim
11-12-2012, 08:21 PM
#42
Malwarebytes
I see your point, In my humble opinion, is a active topic.
Is many that run into the problem all the time, and was some info given by all on it.
For others in the future that want to use the search function, may find what they need.
11-16-2012, 07:41 PM
#43
Malwarebytes
Originally Posted by kwikfishron
Is this program worth paying for? Is there something better out there for the 25 bucks?
Yes and no. Stay away from free antiviruses. You get what you pay for.
All of the pcs I have had to totally restore this last year were protected by a free av program, specifically avg and MSE.
digitalplumber is just a name for use here, I am not a plumber!
11-16-2012, 09:30 PM
#44
Malwarebytes
Stick with Microsoft Security Essentials. It's free and if you maintain it there won't be any issues. You must update it regularly and run it at least weekly. It is the best free anti-malware program, it is fully operational. Anyone having an issue with MSE didn't keep it updated or run it enough.
11-16-2012, 09:40 PM
#45
Malwarebytes
It's one of the worst out there! Run it enough, non sense it is suppose to protect you all of the time!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
