M/B Replacement - PC Repairs & Upgrades - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 03-28-2012, 03:13 PM   #16
Ravenworks's Avatar
Originally Posted by Ironlight View Post
I'm pretty sure they are wrong. The issue is that if the hardware configuration changes to a certain degree, Windows will require you to re-authenticate the installed copy either online or over the phone.
Changing the motherboard alone is enough to trigger the need for reauthing, but you can do it with any copy of Windows, be it OEM or retail. It's simply a way for Microsoft to make sure you don't install one registered copy on multiple machines. I have OEM copies of both WinXP and Win7 running on machines that I routinely upgrade with new components, including motherboards and processors, and reauthing is an easy process.
That, said, the motherboard on a laptop these days includes pretty much everything...processor, sound, graphics, wireless, so it may behave a little different. I have not tried it with a laptop but I'm going to assume that reauthing is the same.
You are 100% correct ,just put the board in and go,nothing to it.
Ravenworks is offline   Reply With Quote
Old 03-30-2012, 12:52 AM   #17
You dont need it install a motherboard so the answer is no. Maybe you would have to install other software such as fan temp programs and stuff but thats it.
Okami is offline   Reply With Quote
Old 04-10-2012, 08:04 PM   #18
Just an update! The project is on hold as the new m/b is dead.
I'm royally bumed off! Took me 3 hours to change the board out and then its NDG!
Old 04-14-2012, 01:13 PM   #19
Ironlight's Avatar
So you're saying that the main logic board on a laptop is a less considerable change than the motherboard on a laptop, and Windows won't consider it enough of a change to require reactivation of the OS?
Ironlight is offline   Reply With Quote
Old 04-14-2012, 03:59 PM   #20
Am now making a eBay claim to eBay. as the m/b supplier will not respond to my emails or phone calls!
Old 04-14-2012, 05:00 PM   #21
the Musigician
DangerMouse's Avatar
Brand new, shrinkwrapped in the box? If so, they're just going to blame it on you. They'll just claim ESD.
I'd never buy electronics for computers online. Buy from a shop locally that accepts returns. If possible, have them test the "whatever" first.
DM
Old 04-14-2012, 05:25 PM   #22
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Did you pay through paypal?
Contact them too if so,very buyer friendly.
Seller,not so much!
sublime2 is offline   Reply With Quote
Old 04-14-2012, 09:55 PM   #23
Seller,not so much!
Yes, I did use Paypal, i'll contact them, also!
Old 04-14-2012, 10:01 PM   #24
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Btw,
The OS installs the HAL (hardware abstraction layer) based on the motherboard so changing it out will most likely make it blue screen. You can swap it out and then boot into a Windows repair and that should fix it.
You need to boot to the OS disk to run the repair.
Old 04-15-2012, 12:18 AM   #25
I have replaced two boards on acer lappys. Both needed to re activate. One worked online, one needed a phone call. I told them that the processor was replaced. They gave me the activation.
Evstarr is offline   Reply With Quote
Old 04-15-2012, 09:13 AM   #26
The activation process seems to depend on which way the wind blows.
My desktop (Win7 Pro-32bit) needed a new m/b. I bought a Biostar m/b (64). I didn't have the Win7 Pro-64, so I down-loaded a copy from MS.
I fully expected to go through the activation process.
When I installed Win7-64, I used the key code that came with my 32 bit DVD.
With a new m/b and an upgrade to 64 bit, I was sure that I would at least have to activate by phone, but it activated without a problem, online!
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
New replacement window problems iminaquagmire Windows and Doors 7 11-11-2011 11:56 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 02:24 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 03:50 PM
