12-20-2008, 10:07 PM
#1
Long distance WiFi
My daughter lives down the road from me (about 300 ft.) and we would like to network our computers. I have a D Link wireless G router its signal seems to be limited to less than 100 feet. I'm looking for suggestions on how I could extend this range!
12-20-2008, 10:16 PM
#2
Electrical Contractor
Long distance WiFi
There are boosters and repeaters available for wifi networks. You might want to look into getting one or more of those components
12-20-2008, 10:57 PM
#3
Long distance WiFi
Thanks for your reply! I suspect a repeater would likely be placed somewhere between the two points. If so, this wouldn't be possible. A booster may be the answer, how do these work?
12-22-2008, 06:35 AM
#4
Safe, Most of the Time!!
Long distance WiFi
You may want to try a new router. I believe the wireless N is suppose to have a range of about 1,000 feet. You will lose some range going through walls, but if you are only talking 300 feet it should work.
I have a wireless N up at the lake, my nephew owns the lot next to me, he is about 200 feet away and he can grab my signal from his cabin.
I can not however grab the signal from my pole shed (about 100 feet away) with the doors closed. I have been told the signal will not go through metal very well.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
12-22-2008, 11:02 AM
#5
Long distance WiFi
I have a house with aluminum siding and that's part of my problem!
My G router signal travels about 100 feet, then its out of range.
I'm really hoping to find two external antenna's (one at each end). I do have line of site capability!
12-26-2008, 06:31 PM
#6
Long distance WiFi
Yes, if you get routers/repeaters/access points with external antennas and can put them in line of site, you should have no issues... especially if you go to N...
12-27-2008, 08:04 AM
#7
Long distance WiFi
Hawking Technology makes wireless computer adapters with USB interface and a 6 db gain antenna. I have used these multiple times with computers located a few hundred feet away, to increase the data rate and connection distance/reliability. Often a quick and easy way to solve the problem. Else you need to learn about higher gain antennas on the access points, setting up a point to point bridge, repeaters, etc.
12-30-2008, 11:39 PM
#8
Long distance WiFi
Wildie,
Previous posters are correct you need a stronger n-router, and almost any kind of low gain antenna, 300 ft is not that far. Heck you could wire her up with cat5 that far. Here is a link for a classy looking cantenna,
http://www.wb8erj.com/wirelessCantenna.html
You'll need one at least on her end, perhaps on router end as well. Pay attention to the length of the probe and other dimensions in the above plan, they are tuned for 2.4 ghz. You'll have to aim them. Make sure you close your network to hackers, you could be supplying the whole neighborhood with internet service.
12-30-2008, 11:49 PM
#9
Long distance WiFi
Originally Posted by sawyerEd
Wildie,
Hey! Thats cool! Thanks for the link! I found another design. It was basically, #14 bare copper wire wound around a foam plastic form. I do like the dryer pipe idea!
12-31-2008, 08:27 AM
#10
Long distance WiFi
Did you find it on the web? If so can you please provide linky?
12-31-2008, 12:18 PM
#11
Long distance WiFi
Yes! its a video at this link! http://tinyurl.com/8q3vl7 Its rather clever also!
12-31-2008, 01:08 PM
#12
Long distance WiFi
Looks like some precise workmanship required for this one, but 16 db high gain is great. God bless the geniuses that can figure these things out!
12-31-2008, 02:30 PM
#13
Long distance WiFi
thankyou
12-31-2008, 05:33 PM
#14
Long distance WiFi
Keep me posted if you try these out!
One question that I have is, how long can the coax be from the router to the anttenna?
02-28-2009, 08:35 PM
#15
Long distance WiFi
Yup, the cable can be a big contributer to loss if very long. LMR is often used for long runs at 2.4 GHz - it has about 6 dB loss per 100 feet at 2.4 GHz. Every 3 dB loss or gain halves or doubles the signal.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
