Irritating Windows!! - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 02-20-2010, 12:09 PM   #1
Tab "a" to slot "b"???
Eric VB's Avatar
Hello all,
Looking for computer knowledge
Does anyone know how to toggle off those irritating preview windows that open up when you place your cursor over a link??
Some times they are helpful but when you are trying to navagate through a page all you see are these little windows popping up all over blocking the text I am trying to read...
Eric
Eric VB is offline   Reply With Quote
Old 02-20-2010, 01:12 PM   #2
Too Short? Cut it Again!
What browser are you using? You do not have to use Safari or Internet Explorer. Try downloading Firefox. It is free. Some like Chrome.
There should be a bar on the top of your screen, for the browser you are using, where you can block pop ups windows.
Old 02-20-2010, 05:41 PM   #3
Eric VB's Avatar
IE8
I have been all over the options trying to find the check box. I don't even know what to look for...preview pane gets me Outlook, mouse hover gets me some automatic program...what is it called when I hover my pointer over a file or thread and it pukes info ontop of what I am trying to read??
Eric
Old 02-22-2010, 09:43 AM   #4
I'm really not sure what preview boxes you're referring to, and I've used IE on computers before (and still do). However, I recommend Firefox. You should just switch.
seawiz is offline   Reply With Quote
Old 02-22-2010, 03:59 PM   #5
Eric VB's Avatar
I attached a screen shot.
Eric
Old 02-22-2010, 04:26 PM   #6
Thats not a pop-up..a preview like you said
Thats a summary of the thread you have the mouse hovering over
Safari, Chrome & Firefox do not show the preview
Is your PC a Dell ?
Old 02-22-2010, 05:16 PM   #7
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
Is your PC a Dell ?
I'm using Firefox on Linux to type this and the hover-over feature works for me, so I don't think your assessment is correct.
I like it, but to each his own I guess.
brons2 is offline   Reply With Quote
Old 02-22-2010, 05:50 PM   #8
Your right, I'm sure windows & Linux are the same
Old 02-22-2010, 06:21 PM   #9
E-lec-tri-city
Rewards Points: 150
I just tried it on my Vista (SP2) box on Firefox 3.5.8 and I was able to see the preview when hovering over links there also. You stated in your previous post that Firefox did not have that capability. So far, as far as I can tell, it does.
Anyways...
I'm guessing one of the reasons that the OP doesn't like the feature is that he's using a lower resolution and it takes up too much of his screen. My Vista box is hooked to a 22" widescreen at 1680x1050 and the preview box is very small, hardly obtrusive at all.
Old 02-22-2010, 06:24 PM   #10
E-lec-tri-city
Rewards Points: 150
I attached an example that I took with the snipping tool in Vista.
Old 02-22-2010, 06:40 PM   #11
I never stated that it didn't have the capability, merely pointed out that on my PC (also Vista) it was not showing up under those browsers
I've looked around & haven't seen anything that turns it off or on
You have Vista & Firefox & it's "ON"...3.5.8
I have Vista & Firefox & it's "OFF"...3.5.8 (3.6 is out)
I don't use Firefox that much
So it seems its an add-on or setting in the browser....not Vista
Old 02-22-2010, 06:45 PM   #12
E-lec-tri-city
Rewards Points: 150
When I tried it on IE in Vista the previews did not appear until I logged into the site. However, I didn't test it extensively or anything. I did look for a setting on this site that was related to the previews but I didn't find one. Oh well, it's time for me to go home anyways.
P.S.: yes I know FF 3.6 is out but an add-on that I use for work is not yet compatible with 3.6.
Old 02-22-2010, 06:51 PM   #13
OK, that narrows it down
I just checked & logged out the previews do not show up on IE & Firefox
So maybe its the VBulletin software
I know they aren't showing up on Craigslist
Old 03-01-2010, 02:54 PM   #14
Fox
Rough around the edges...
Fox's Avatar
Unfortunately that's a 'feature' for registered members of the forum. You'll notice that even if you're not logged in, if you hover over a username of the last poster to the right, you'll still get these windows. (Officially called 'tooltips' I believe.)
Be it ActiveX, JavaScript or some other programming language that is permitting these issues is beyond me at the moment (I really can't do that much research into it) but attempting to disable this would require one of two routes:
1. Disable that language on this page, likely crippling much of the page itself as well
2. A custom-written css styling sheet, or something similar that would require commissioning a programmer
Sadly, I didn't notice these until they were just pointed out to me...
Fox is offline   Reply With Quote
Old 03-01-2010, 03:00 PM   #15
if you are using firefox you can look into a greasemonkey or stylish script to remove them without crippling the page itself. i personally can't write it for you but i can't imagine the coding is that difficult.
if it helps - they only show up for me if i hover over a link. i usually click pretty quickly so i don't notice them.
cellophane is offline   Reply With Quote
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 08:56 AM
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
New Windows installed over old windows Lakehome Remodeling 1 03-14-2009 01:39 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
