#1 |
I upgraded to windows 7
When I up graded from xp to windows 7 now my DVD rom don't work and my sound card won't work it a sound blaster
#2 |
You probably need to update the drivers. You should be able to get them from the manufacturer's website.
| The Following User Says Thank You to djlandkpl For This Useful Post: | snowman21385 (02-06-2013) |
#3 |
Open up the side and pull the power to the DVD rom then turn on the computer. Plug it back in after it boots up...Windows 7 is SUPPOSED to look for drivers when new equipment is installed.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 | |
I upgraded to windows 7Quote:
I'd remove the drivers for the devices not working ( click the cute little windows circle, type device manager in the "search windows and program files" and tap the enter key. in device manager, you can click DVD/CD rom drives plus sign and delete the dvd drivers, same for the sound card. reboot. note your devices may not be supported with windows 7 drivers, you can try the manufacturer web site if the above does not work. |
#5 |
I looked on the web and no more updates for sound card but I don't have $ to get xp or vista back on it I know it's a down grade but when my comp crashed I put windows 7 on it and clean wipe
#6 |
Did you first run Microsoft's Windows Upgrade Advisor to see if your computer was suitable for upgrading to Windows 7? Even if it is, the program would've told you any issues you might have or special steps you might need to take.
I upgraded my Dell laptop from XP to 7 a few weeks ago. Like you, I had a couple of potential driver issues. Since the model I have is a few years old and not in production any more, Dell has no Win 7 drivers for it. Fortunately, the Vista drivers on the upgrade disc were "close enough." |
#7 |
1st thing I'd try:
1) Open Control Panel 2) Click on Device Manager 3) Scroll down to Sound, Video and Game Controllers 4) Right click on the listed sound device (probably listed as i.e., Creative SB X-Fi) 5) Choose "Update driver software" from resulting pop up menu. Do the same thing for the DVD drive. Note: The DVD drive issue may be due to the drive being on a different motherboard controller. In this case, use the same steps for the controller. If not available, you may need to use the MB manufacturer's drivers. Any device with a yellow triangle has a driver issue. Last edited by Bob...; 02-12-2013 at 01:41 PM. |
#8 |
for a lot of devices the windows vista drivers will work. all you can do is try them if they are available. if they don't it what they call planned obsolescence.
#9 | |
If doing the things recommended above don't work, try Googling the model number of your device and "Windows 7" to see if anyone has found a workaround (sometimes there is a compatible driver for a newer device, etc). Otherwise you might have to spend a few dollars on a new drive and audio card (neither of which are expensive, especially if you just hit ebay). |
#10 |
You mentioned you are tight on money, but this might be within your budget. You will probably be able to find a new generic audio card for under $10 delivered and a new DVD drive for under $20 delivered from places like Newegg and eBay. Both Win 7 compatible.
#11 |
Yep, definately check Newegg. I got 2 Samsung DVD burners for $14.00 each.
#12 |
Go with your control panel option first. If it's a simple upgrade/driver issue then that should do the trick. If not, then Newegg. It gets good reviews and is easy on the wallet.
#13 |
JOATMON
Windows XP to Win7? How old is that computer? I have a feeling you wasted some money.
Because your computer crashed, is a poor reason to upgrade your computer.....maybe it crashed because you have hardware issues. Sort of like putting a new paint job on your car because it's running bad. Not sure why $$ is an issue going back to XP....if you had it before, then you still own the license. If you lost the info....then, well....might explain why your having issues. As a final note....this place is a great place for help...but there are better places to get computer help
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#14 | |
paper hanger and painter
http://ths.gardenweb.com/forums/comphelp/
#15 | |
![]() ![]() ![]() first thread I clicked on was one asking "how to get my email and passwords.?" |
| Display Modes | |
| Any restitution for VERY late windows? | msbriggs | Building & Construction | 21 | 10-05-2010 07:25 AM |
| Windows XP Mode in Windows 7! | poppameth | PC Repairs & Upgrades | 5 | 04-28-2009 01:18 PM |
| How do I install new windows? | RickT | Carpentry | 17 | 10-12-2006 07:06 PM |
