Firefox Resolution! - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 03-16-2009, 09:45 PM   #1
Firefox resolution!
My friends HP laptop, running Vista runs Firefox at minimum resolution. Looks zoomed in and over magnified.
The computer is identical to my own, so its been easy to see what the settings should be!
The FF profile path is C:\users\user\appdata\roaming\mozzila\firefox\prof iles\xxxxxxxxx\default. on my computer.
However, on his computer the APPDATA directory is missing. I tried making this path up manually, but it didn't work. I even down-loaded a new copy of FF and re-installed it with no luck!
My question is, how do I replace this directory that is missing?
Old 03-18-2009, 12:31 PM   #2
Make sure that show hidden files is turned on and possibly hide system folders is turned off. I also noticed on my machine that local group "everyone" had zero access to the appdata and a few other dirs causing an access denied despite local admin access, I needed to change Everyone back to read access etc.
Also in FF check options/content/advanced, make sure there is no minimum font size and try different options there etc.
destroyer427 is offline   Reply With Quote
Old 03-18-2009, 05:06 PM   #3
You are right on the money with this! In folder options, hide system files was checked!
That sorted it out!
Thanks!
Old 05-12-2009, 09:45 PM   #4
FYI -- Firefox allows you to zoom in and out. Hold down the control button and click on either the + or - keys. Very nice feature! Sounds like you might have been zoomed in by mistake and just needed to zoom back out a little.
PunkyPoo is offline   Reply With Quote
Old 08-08-2009, 04:27 PM   #5
So you located the folder but was the problem solved?
GoFins is offline   Reply With Quote
Old 08-08-2009, 09:13 PM   #6
Yep, Destroyer427 had the answer!
Ice Dam Resolution? capeowner Roofing/Siding 5 02-19-2009 10:12 AM
