Fan On Comp - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 03-03-2009, 04:51 PM   #1
fan on comp
ok so here it is my computer once in awhile starts t make a load noise i discovered it is one of the fans. all i have to do is tap on it and it goes away. should i replace the fan or what should i do will it harm thr computer if i dont replace it.
chefjb98 is offline   Reply With Quote
Old 03-03-2009, 05:04 PM   #2
the Musigician
DangerMouse's Avatar
there are numerous fans on any given machine, which fan makes the noise? power supply? cpu? *other*?
any of them can and should be replaced if the bearings are going out. it will harm the machine by overheating whatever component is being cooled.
DM
Old 03-03-2009, 05:06 PM   #3
Could be a loose screw, or a bearing going
Old 03-03-2009, 05:13 PM   #4
this is not helping but anyway, they installed a brand new computer in work shop at work, from day one, I can hear the fan making vibration noise, I haven't tapped it for a long time now, been a year or so and no problems. I guess if it was my personal one at home, I'd take it apart to get a better look.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 03-03-2009, 05:15 PM   #5
the Musigician
loose screw? maybe, or it could be the flimmerstat chip on the mitterboard fried the flandular connection at the crapacitor...?
DM
Old 03-03-2009, 06:04 PM   #6
Could be a loose screw but also check the loose wires, I had a wire that would rub the fan blades every now and again.
Lilith785 is offline   Reply With Quote
Old 03-04-2009, 08:24 AM   #7
Could be the case...which fan is it?
DM
flimmerstat's can go pretty fast when overclocking. Ususally the voltage is increased at the tranducer's rectifier when the fsb is increased. This pushes high voltage into the crapacitor. This is upwards of 50 amps depending on your 12v psu rail. The flandular connection will melt and the crapacitor will leak.
rgsgww is offline   Reply With Quote
Old 03-04-2009, 08:46 AM   #8
the Musigician
Originally Posted by rgsgww View Post
flimmerstat's can go pretty fast when overclocking. Usually the voltage is increased at the tranducer's rectifier when the fsb is increased. This pushes high voltage into the crapacitor. This is upwards of 50 amps depending on your 12v psu rail. The flandular connection will melt and the crapacitor will leak.
absolutely correct!
DM
Comp shingle recommendations needed Arndavis Roofing/Siding 7 06-07-2008 10:01 PM
Roofing, Labor only ???? olie Roofing/Siding 33 11-06-2007 12:31 PM
Staples with comp. shingles? scarrell Roofing/Siding 9 04-23-2006 10:38 AM
