Dropped My Pc - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 10-26-2006, 08:24 AM   #1
dropped my pc
Hi everyone HELP. i dropped my pc and now it starts up for about 3 seconds then cuts out. the processor cooling fan starts going then all goes off. and you have to wait a few seconds before trying it again. i havnt got a clue and dont want to buy another pc if i dont need to.
Thanks mat125
mat125 is offline   Reply With Quote
Old 10-27-2006, 07:27 PM   #2
so the computer starts up but then locks up or bluescreens later?
that could be a heating issue.
you may have knocked your heatsink off your processor or it is loose. make sure the heatsink and the fan on top are not loose whatsoever and are making direct contact to the cpu. you can also buy something called "thermalpaste" and put it in between your cpu and heatsink if you find that was the cause of the problem. the thermal paste will help the heat flow off of the cpu and into the heatsink making your computer run more smoothly
newbhomeowner is offline   Reply With Quote
Old 10-29-2006, 02:52 PM   #3
still nothing
thanks for the advice, that still doesnt seem to work my pc seems to want to start and sometimes goes a little while longer but doesnt regester on my monitor. i hope this makes sense. when i used to turn on my pc it would place the win xp load screen on the monitor, now however i get nothing because the tower doesnt stay on long enough.
mat125
Old 10-29-2006, 09:03 PM   #4
NothingsLevel's Avatar
Are you certain that all your connections are tight? No expansion cards got knocked loose? Re-seat every connection and card to make certain.
Does anything rattle around, like a loose screw?
I agree w/ newb that it could be heat, but it shouldn't be shutting down so fast if it's purely a heat issue.
NothingsLevel is offline   Reply With Quote
Old 11-01-2006, 07:47 PM   #5
Pro Painter
You dropped the tower?
If all the pci boards and other connections are tight and everything seems to be in place, it's possible that you have a crack in the Motherboard.
joewho is offline   Reply With Quote
basement renovation yummy mummy Remodeling 156 05-08-2007 10:15 AM
