Drive Contents Transfer - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 06-24-2011, 07:04 PM   #1
Handyman
Rewards Points: 512
Drive contents transfer
Well, here I am again wishing PC's were made of 2x4's lol
Here is my situation... bought a used PC with Windows XP Pro. My existing is XP Home. My existing PC is IDE and the new one is Satta so I can't just install my old drive. File transferring is not a problem because I can use my external hard drive as a copy/paste utility. I want to transfer some applications though, such as, MS Works and Links2k3 and other stuff of which my original disks are, let's say...unkempt. Is there a way to transfer my existing contents to another drive in a different PC.
Dave
canadaclub is offline   Reply With Quote
Old 06-24-2011, 07:26 PM   #2
Rewards Points: 252
You have to re-install most applications like word, excel, etc. You can try Softpedia.com for downloadable software, but you will still need your license to activate it.
There are also programs that can read your license from the current hard drive you can use to get your license #'s for most microsoft and other products. If you have a program that is obscure with low distribution, it may be difficult.
Marty1Mc is offline   Reply With Quote
Old 06-25-2011, 04:44 PM   #3
the Musigician
DangerMouse's Avatar
....or for $15.00....
http://www.newegg.com/Product/Produc...82E16812232004
DM
Old 06-25-2011, 04:47 PM   #4
most computers come with the sata but usually still have an ide connection on the motherboard unless they have phased them out. cd roms are still ide and sata.
Old 06-26-2011, 10:08 AM   #5
there are programs that will make an image of your hard drive and install it to the other hard drive. you should be able to hook your hard drive up as the boot drive in the computer you bought. you would have to install drivers for the hardware in that pc tho. they did give you the disc for the motherboard? some programs are self contained in the folder they install to but others put files in other places so some you can copy the folder over to the other hard drive and make a shortcut and it will work others wont.
Old 06-26-2011, 04:50 PM   #6
Rewards Points: 6,652
Easy way is to just reinstall the software. Transfering is a pita. Now since the new machine only has SATA connectors, you can get a PCI card for IDE drives, and then put the old drive into the new machine. One problem is, you will have to learn how to set up the user security on the old drive, so you can access from the new drive (use same username & password on new machine).
More info can be found at majorgeeks.com, which has a great support forum that this has been discussed over and over.
Old 06-26-2011, 04:57 PM   #7
this might help you
http://ezinearticles.com/?How-To-Tra...ter&id=1163480
http://faq.programmerworld.net/pc/tr...nd-new-pc.html
http://www.laplink.com/pcmover/pcmoverpro.html
Old 06-26-2011, 05:13 PM   #8
Actually Danny, the software is already built into XP to move files. It is under the Accessories > System Tools. No extra software is needed. Only catch is, that it works for machine to machine, but drive to drive with programs that have been installed with a disk from the software manufacturer, you are better off just reinstalling. Transferring files from My documents, music, etc, can be done by doing what I stated, or File transfer with Windows XP, as long as both are on your LAN and both machines work.
Old machines that are in good working order, I will usually run them as a file server, or run pfsense as a router box, when I had Comcast as my provider. Now I have U-Verse, and do not feel like layering, but still looking at putting a file server on the network, since I currently have almost 200gb of music sitting on one of my machines, that is used as a workstation, but is usually offline, unless we need to use it, for printing and such.
Old 06-26-2011, 05:17 PM   #9
i find it hard to believe that the new computer doesnt have an ide header to hook his old drive to. i know they are phasing out ide but most motherboards still have 1 ide header.
Old 06-26-2011, 05:30 PM   #10
Rewards Points: 252
All depends. Most aftermarket motherboards of that vintage have IDE support. However, major manufacturers don't build in features that are not needed on low end equipment. Cost competition is too strong to add features that are not used.
Old 06-26-2011, 05:31 PM   #11
since he said it was used and had xp on it i didnt figure it would be sata only.
Old 06-26-2011, 05:34 PM   #12
That is okay Danny. I had to read the orig. twice to catch the IDE. Actually what I described, works for any computer, regardless if IDE or SATA, due to since XP, that Microsoft has incorporated some nice features. Another way of doing it, is to use a Linux LiveCD and tranfer info that way also between machines. There is more than one way to skin a horse, or in this case a Microsoft machine.
Old 07-22-2011, 01:52 PM   #13
Rewards Points: 83
Trying to transfer applications is problematic because the installation process creates a lot of files and particularily adds a lot of information to the registry which is not done when you just copy files or folders. If it is just an application or two, it would be easiest to just re-install (unless you do not have the install disks). You can make an image of your old disk and then just load the image to the new computer and then the new computer will have all of the software and the operating system that was on the old computer. It does not matter what type of drive the old or new computer has as long as the new one has at least as much capacity as the old one. I used a usb external drive and make a monthly image of my drives anyway as my normal backup, so I always have a recent up to date image of my hard drive.
davido30093 is offline   Reply With Quote
Choosing a manual transfer swtich for 7500 w generator homerb Electrical 11 07-24-2012 12:15 AM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 12:36 AM
Satellite Rx external hard drive. Wildie PC Repairs & Upgrades 4 09-13-2009 11:06 PM
Moving C drive files Thurman PC Repairs & Upgrades 14 08-17-2009 03:13 PM
Generator with 2 transfer switches? Isaac-1 Electrical 4 03-16-2009 07:45 PM
