Dlink WiFi Adapter Antenna Problem - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 08-07-2014, 07:10 AM   #1
Dlink WiFi adapter antenna problem
Hello everyone, I am trying to build myself a helical style antenna and connect it to a wireless adapter. My wireless adapter is a Dlink DWA-123. Now I have taken it apart but I can't figure out which part of it is the internal antenna to which I will connect my home-build antenna. I have attached 2 pictures of each side of the PCB so I would like to ask, where should I connect my antenna cable?
Front side PCB
Back side PCB
Note: I think it might be the holes in the upper right of the first photo but I can't figure out where to connect the ground and the core wire.
Tzeny is offline   Reply With Quote
Old 08-07-2014, 09:27 AM   #2
Problem solved; most likely I can't and I have to use a wifi adapter with an antenna port.
Old 08-07-2014, 01:02 PM   #3
Retired from the grind
Rewards Points: 6,652
You have to get the cable that adapts from that connection to a proper end. This is the cable you need. http://www.amazon.com/Mini-Antenna-R...i+pci-e+to+sma
Modifying laptop ac adapter - Confused. miller108 Electrical 7 01-14-2013 08:49 AM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 11:00 AM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
