Demagnetized - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 09-06-2007, 03:32 PM   #1
demagnetized
I accidentally put my computer on a demagnetizer. Even though I successfully installed the recovery disk, my computer will shut down while unzipping all the files. It says I see this blue screen because it's preventing damage to my computer. Then it dumps all the physical memory. It will restart and then shutdown minutes later. This continuously happens. Do I need a new hard drive? Is anything else potentially damaged?
calberto is offline   Reply With Quote
Old 09-06-2007, 05:36 PM   #2
Remodeler
MinConst's Avatar
If you put your whole computer on a demagnetizer I would say it is shot. You probably erased or corrupted some chips, cards, memory, hd.
You might try a new hd but it's doubtful.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-06-2007, 10:56 PM   #3
Cabinet Installer
Dansbell's Avatar
Blue screen is a memory problem. It could be any number of things that use the system memory. I suspect this is a notebook, if not try pulling all your PCI cards and rebooting. You may try pulling your ram a stick at a time to try and find a bad one. Most likely you will be replacing your ram if not your whole computer. These things don't even like static. You have destroyed some electronic part, I doubt it was the hard drive. If you demagnetized your computer you have possibly wiped your bios along with other chips. I am surprised you were able to reinstall the OS. I got to know, How you accidentally demagnetized it. This has got to be a good story.
Daniel S. Bell
Belbuilt, LLC
Cabinet Installation Medford, Oregon
http://www.belbuilt.com
Dansbell is offline   Reply With Quote
Old 09-08-2007, 12:50 AM   #4
I was opening a store that I work at. Usually I listen to music from my notebook. W/o thinking, I put my notebook on the demagnetizer. *BUZZ* Immediately my first thought was F*&@!!! Sure enough, the computer stopped functioning. I manually restarted it and then that's when all the problems occurred. Anyway, since it could be any number of problems, I'm going to get a diagnostics test at Best Buy. I appreciate both your help. Thank you.
Old 09-08-2007, 10:58 AM   #5
NothingsLevel's Avatar
A bluescreen is not necessarily a RAM problem. RAM chips shouldn't be damaged by a magnetic field.
Does your recovery CD repartition and reformat the hard drive? If not, you really ought to take that step to make sure the drive isn't completely scrambled. Or, even worse - it might need a low-level format.
NothingsLevel is offline   Reply With Quote
