Could Cell Phone Charge Drain Car Battery? - PC Repairs & Upgrades - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades
Old 08-12-2014, 06:15 PM   #1
Rewards Points: 1,062
could cell phone charge drain car battery?
Heard it could, especially if you leave it charging while car is "off", as in not being driven/engine off, of course. Seems like a cell phone wouldnt need so much voltage, sheesh. Is this true, people?
Also, does a car have to be with engine on for same voltage to "seep" into the cell phone to charge it? The cigarette lighter I understand is always on the ON position, so shouldnt it be emitting the same voltage weather the engine is on/off, sine lighter terminal is always ON?
Thaks
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 08-12-2014, 07:34 PM   #2
DIY staff
Rewards Points: 7,174
I forget to unplug my charger and never had an issue with it draining the battery noticeably--
My truck battery is about 11.25 volts at rest--and 14 volts when the truck is running---
noquacks (08-13-2014)
Old 08-12-2014, 08:53 PM   #3
joed's Avatar
Rewards Points: 12,918
A cell phone will not drain a car battery. The on board computer draws more power than the cell phone charger would.
The Following User Says Thank You to joed For This Useful Post:
Old 08-12-2014, 08:58 PM   #4
First Home N00b
Rewards Points: 202
Thaks
It's all about the amps. Yes, it does drain the battery. Does it do it to any meaningful level? Being that most USB chargers are 1A or 2.5A, no. The radio and PCM keep alive memories are both a greater amperage. It's not a good idea to leave any load on a car battery without the charging system running.
95PGTTech is offline   Reply With Quote
The Following 2 Users Say Thank You to 95PGTTech For This Useful Post:
concretemasonry (08-12-2014), noquacks (08-13-2014)
Old 08-12-2014, 10:53 PM   #5
Rewards Points: 1,010
And unlike a house hold charger, an automobile charger won't drain the battery if the phone is not plugged in
Anti-wingnut is offline   Reply With Quote
The Following User Says Thank You to Anti-wingnut For This Useful Post:
Old 08-13-2014, 06:52 PM   #6
Big thanks, people. So, I figured that had to be bogus scare type info- but Im still not clear on this: is the same amount of charging "power" available to a phone being charged the same as that of same terminal (cigarette lighter) while engine is running? Isnt the lighter terminal a steady voltage output- car on or car off??
In other words, if my phone needs lets say 4 hours of charge with car off, will it be charged in less time if car is running/engine running?
thanks
Old 08-13-2014, 10:30 PM   #7
Rewards Points: 3,788
Your voltage is higher with the engine running. While the battery is 12 volts (slightly less actually), the alternator (while turning) will put out anywhere between about 12.5 volts to 14.5 volts.
This shouldn't make too much of a difference with your usb charger though since the voltage is chopped at 5 volts.
Bob Sanders is offline   Reply With Quote
The Following User Says Thank You to Bob Sanders For This Useful Post:
noquacks (08-16-2014)
Old 11-25-2014, 09:01 AM   #8
Rewards Points: 202
I agree. It should not drain car battery. If your battery keeps on draining for whatever reason you should probably have it checked.
PD_Lape is offline   Reply With Quote
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 11:33 AM
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
1994 jeep battery drain Daverimmer Automotive Repairs 10 10-29-2010 01:33 PM
